Replacement Keyfob
Discussion in 'Gen 3 Prius Audio and Electronics' started by Au-Toe, Nov 30, 2012.
  1. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    long story short, there was a small fire in my home. the keyfob (remote/key) casing/plastic melted a little bit.
    the remote still works. unlocks the car fine.
    but the casing its burnt and melted.
    the problem is, our prius is leased and we'll most likely return it back when the lease is up this coming may 2013.
    i assume all the electronics are okay in the remote. anyone ever replace theirs, without having to go to the dealership and having to pay an outstanding price.
    any helps or thoughts?
  2. TsKarma
    TsKarma Junior Member
    82
    It may help others to give you a better idea/suggestion if you post a picture.
    Can you still remove the casing to do either of the following?
    Take the emergency key out of it's slot, or
    remove the external casing to expose the fob's battery, etc...
    What do others think, just buy the cheapest used fob possible on ebay, etc...and then use it's external casing to replace the burnt/melted one?
  3. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    i'm at work, having my wife take a pic for me. will try to post one soon.
  4. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    attached the file of the burnt remote. hopefully you can see it well enough
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    My suggestion is to claim the fob on your insurance. If it was damaged by fire your insurance should cover it. If you don't have insurance you are SOL.
    Tom
  6. truthfulman
    truthfulman Junior Member
    I bought a guaranteed fob on e-bay for $88. There were cheaper ones but the guarantee was important to me. The fob came with an uncut key. I had a mobile locksmith come to the house and do a complete ECU reprogram for both fobs for and cut the additional key for $100.00. The total was 1/2 the price of the dealership.
