Replacement Scissor Jack
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Sep 9, 2020.
  1. andreimontreal
    andreimontreal Active Member
    347
    109
    28
    Montreal
    I've accidentally forgot my car jack under the car near the wheel, moved the car and bent it slightly and it's not working properly anymore. I need a replacement - I think (it out of alignment, not safe at all anymore). I need ideas for sources to replace this: oem or something sturdier, if you know of a better option - would you still get the oem?
    EDIT: Ontario store: oem one is 125 CAD plus whatever shipping and taxes. Amayama 90 cad (105 with shipping, seems my best so far).
    Andrei
    #1 andreimontreal, Sep 9, 2020
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,352
    2,346
    Taylors, SC
    The Gen 3 Prius uses "knife edge' pinch welds. The jack supports the car on a small reinforced pad inside the chassis behind the pinch weld. The proper jack looks like this. Many are available for about $50 on eBay. Gen 2-3 oblique view.jpg
    #2 Georgina Rudkus, Sep 9, 2020
    andreimontreal likes this.
  3. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    ...or you might check your local salvage yard for a previously owned jack in new condition.
  4. Salamander_King
    Salamander_King Senior Member
    11,009
    8,934
    New England
    eBay is your best bet. I could sell you my extra one cheap but the shipping cost may make it more expensive than buying from eBay. If I have to replace my jack, I would buy a better and easier portable hydraulic jack. Something like this but lower. The one in the link is 8-5/8 inch tall, and will not fit under the Prius, I think. Also, it may not fit in the spare tire compartment. You may have to look for suitable for your car, but having used the scissor jack on our other car recently, I am sure any portable hydraulic jack would make the job easier. There are some electric ones too.
    #4 Salamander_King, Sep 10, 2020
  5. Mendel Leisk
    40,574
    I like those (collapsible) wheel stops. Toyota should include them, plus the tools and carrying pouch. (y)
    Majafamily likes this.
  6. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    And then the car would be much more expensive; take the cost of the pouch and multiply by 3 and bill the buyers :LOL:
  7. andreimontreal
    347
    109
    28
    Montreal
    Some good ideas.
    My only issue: space.
    I was actually thinking about that too when I saw those.
    A
