Replacement tires that give better mpg than the stock Integritys
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Struv1, Jun 8, 2008.
  1. Struv1
    Struv1 New Member
    Upland, Ca
    In reviewing previous posts, I don't see one that focuses on bringing up mpg from the stock OEM tires. For all that have replaced there OEM Integrity tires, have any seen there mpg go up? Brand/Model and before/after mpg #'s would be appreciated. I have heard mixed results that Intergritys are LRR tires... So that opens the door for possible mpg improvement.
  2. Struv1
    Struv1 New Member
    Upland, Ca
  3. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Nokian WR's, any of the Michelin energy series.
    Wayne
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Nokian I3 stock size 185/65/R15. It is the only known tire that is lighter than the Integrity. It has 80,000 miles warranty. You can get it for $55 each. Can't beat that.
    I have about 200 miles on it and averaging 55.5 MPG (about the same as Integrity). I am running 47 PSI (max for I3) for the front and 45 PSI in the rear.
  6. Struv1
    Struv1 New Member
    Upland, Ca
    Thanks for the replies...I'll look into the recommended...
  7. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    treat suggestions here carefully as some people speak nonsense with authority. The suggestion to look at Nokian is valid, but not all of their models. The WR, WRg2, and H models are Low Rolling Resistance. I believe that the I3 is not. There are a few other LRR tires on the market such as the Michelin "Energy Saving" series (not the other models discussed in these groups). See the attached Excel file for data on my 120k miles of experience with Goodyear Integrity, Michelin MXV4+, and Nokian WR tires on my 2004 Prius.
    JeffD
  8. brick
    brick Active Member
    1,083
    78
    Upstate NY
    Wow. I just spent some time reading reviews of those Nokians (WR), and they sound great for if/when I move back to snow country.
  9. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    This is AWESOME data.
    Just needs a laymen's conclusion for us ADD sufferers, in respect to overall best tire(included in file) for MPG
  10. hiremichaelreid
    hiremichaelreid New Member
    451
    Ottawa/Aylmer, Canada
    I
    So, if you want LRR you've got:
    Nokian WR, WRG2 or H.
    Michelin "Energy Saving" series (eg. MXV4+)
    If you want an LRR tire that's fully certified for snow, AND is good to drive all year round that leaves just:
    Nokian WR or WRG2.
    These are my prospects for this fall, here in "snow-land". Despite all the posts I've read, it's still hard to understand exactly the difference between them except g2 is newer and better in slush. Some have said WRG2 replaces WR but both are still on Nokian website.
  11. jammin012
    jammin012 The man behind The Man
    510
    Cali
    From the spreadsheet I see the Integrity wins on the mpg front.
  12. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    I3 is not advertised as LRR in USA but it is in Europe. See below quote from their site. I have 850 miles on them now and from coasting on my regular route, I can tell they are lower rolling resistant than the Integrity. Partly because I am running 47/45 PSI vs 44/42. However, I3s are not broken in yet. I have 71k miles experience on the Prius. I know how the ultra performance summer tires with 17" drives like. From that two data points (Integrity and Nexen), I can tell I3 coast further more than the Integrity. For $55 each, I truely believe they are a bargin with 80k miles warranty!
    "Nokian i3 maintains a good grip in rainy and cool conditions. The full silica composite (Nokian cool silica compound) is designed for Nordic conditions. The tyre maintains its grip properties in cold spring mornings and in the cool early autumn, even when temperatures drop below 10 degrees centigrade.
    The tyre features three prominent main grooves, and lateral grooves open to the side, giving the tyre excellent hydroplaning properties.
    The acoustically optimised tread pattern and noise cavities in the grooves dampen tyre noise.
    The ecological nature of the Nokian i3 is particularly evident in two features. Similar to other Nokian tyres, no high aromatic oils are used in the manufacturing process. The tyre is also economical: it rolls easily and consumes little fuel."
  13. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Note that there are some other LRR tires, it's just that I don't have solid info on them. The Nokian WRs have a very aggressive tread design. This makes them great in snow/slush, but a little noisy. The WRg2s have the same tread on one edge and a "Touring" tread on the other. This probably reduces both the noise and snow traction, but I don't see where they would be better in slush. I view them as a compromise for less snowy regions.
    I see that the I3s may indeed do well in MPG, but someone needs to document some good comparison data so that we can evaluate their performance. My comparisons held the PSI the same for all three tires (42/40) even though the WRs can be inflated safely to 51.
    JeffD
  14. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Then you don't know how to read data.
    The Michelins win by a whisker over a full year (due to better cold weather MPG) and when you adjust properly for the effects of revs/mile the difference is about 1% in favor of the Michelins. It looks like the WRs will beat the Integrity tires by more than 2% in MPG over a full year, but I'll have to wait until November to do that calculation.
    JeffD
