Replacement Tires
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Black&White, Feb 13, 2015.
  1. Black&White
    Black&White Junior Member
    My tires are past the wear bars, I'm only at 40k, is this normal? I admit, I run high tire pressures. What kind of tires do you guys recommend I replace these with? I saw some speak of the Michelin Premiers? do they sell those in the same size as my stock tires?
    Thanks
    #1 Black&White, Feb 13, 2015
  2. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Which ones were OEM fitted on yours?
  3. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
