Replacement Tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sue_CT, Apr 10, 2015.
  1. Sue_CT
    Sue_CT Junior Member
    Connecticut
    Can anyone recommend good all weather replacement tires for 2008 base model? The originals were terrible here in CT, so I did get snow tires, but the original tires now need to be replaced. I would like something better in snow and rain than the originals. I may always need separate snow tires for heavy winter snow, but with the original tires, any snow at all on the road meant I couldn't get up hills. Lived my whole life in CT and this is the first time I HAD to get snow tires. In the past any car I had did well with just a really good set of all weather tires. But I guess I would settle for just not having to use snow tires from Oct through the end of April. I love the good gas mileage, but I am looking for the best safety and handling rather than the ultimate gas mileage.
    49,378
    michelin energy saver a/s.
  3. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Since, you're looking for better wet/snow traction and are willing to sacrifice a bit of fuel economy in exchange for handling/safety, I'd suggest the Michelin Premier A/S. It has superior grip over the Michelin Energy Saver A/S, especially in light snow and rain.
  4. Sue_CT
    Connecticut
    Thank you. The Premier a/s get good user reviews on Tire Rack. The energy saver, no as much. Has anyone ever used the Continental True Contact?
  5. se-riously
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    It's a new tire, so reviews are more limited, but user wjtracy has them. You should PM him.
  6. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,573
    Iowa
    I was told, that the best for what you are looking for is the Michelin Defender, the Michelin Premier A/S and the Goodyear TripleTred.
    I have the TripleTred on a Camry and love them. I have the Goodyear FuelMax on the Prius, but since I never drive it in snow....
  7. iflutist
    iflutist New Member
    16
    Halifax
    I am trying to decide between the Premier and TrueContacts, too. No Defender size for the v I am told.
  8. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    If I were to purchase new tires now, I would choose the Continental TrueContact. They have incredible survey results in all categories, are supposed to roll well and are made in the stock size.
    I am using the Hankook Optimo H727 and love their all-weather performance, but I had to go with a wider size, and the TrueContact has even better survey results.
  9. iflutist
    iflutist New Member
    16
    Halifax
    Where I am, I am getting quoted cheaper for the Premiers than the TrueContacts by $50. Now it's gonna be tougher to decide
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    It looks like the Premier A/S even edges out the TrueContact in survey results. Those sipes look great for snow. I'd go for it!
  11. iflutist
    iflutist New Member
    16
    Halifax
    Interesting turn of events. The Prius v came with Michelin Energy Savers AS 91V but they are already down to 4/32 or below and we've only had them for 3 years and no more than 40K actual mileage on them. Pretty disappointing. Called Michelin and will take the tires in for assessment. First time doing warrantee. Would love to see if they'd let us swap out for Premiers instead!
  12. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    Just took another look at Tire Rack for survey results on the Premier A/S vs. Truecontact, and it looks as though Truecontact wins--all "superiors" but for one "excellent," including a "definitely" on the question of whether the reviewer would buy again, whereas the Premier A/S had four "excellents" and a "probably" on buying again.
    Sue_CT likes this.
  13. Sue_CT
    Connecticut
    Thank you for all your input. Looks like the TrueContact will win, but was hoping someone here had used them. The survey results are impressive, however.
  14. ktyler2
    ktyler2 Junior Member
    25
    Utah
    I bought a used 2009 Prius a few months ago. The OEM Integrities were pretty worn even though the car only had 27,000 miles on it when I bought it. After doing my own research, I decided to replace them with Continental TrueContacts. I live in Utah and drive 85 miles a day for work, mostly on the highway. The most important things for me in a tire are tread life, fuel economy, and all-season traction. So far, I have been extremely happy with my choice.
    Compared to the Integrities, I notice MUCH better traction on wet roads with the TrueContacts. We even got a pretty bad snow storm here last week, and these tires held up great. I am confident they will do well through all the winter conditions I see here.
    In regards to fuel economy, I would put them on par with the OEM's. I believe the Integrities are pretty good as far as gas mileage, so I was not expecting an improvement here. I do run my tire pressure at 42/40, so ride quality isn't the smoothest. After 3,500 miles on these tires, I am averaging about 52MPG.
    I don't have much to say about longevity of the tires at this point, but considering I was able to work them for free into my agreement at the dealership, I'm not too worried about it.
    PROS: Excellent traction (wet and dry), good fuel economy, warranty, price
    CONS: Not the smoothest or the quietest (at 42/40, i'm not really aiming for these things)
    Feel free to ask my anything you'd like about them! I'm also about to replace the tires on my wife's 2007 Highlander and I am considering getting another set of these...
  15. Jim T
    Jim T Junior Member
    22
    New York State
    I can recommend the Michelin Premier A/S. I've had the Goodyear TripleTred on our VW Passat (same 195/65R15 size as my Prius) and it wore to about 3/32" in 50k miles out of an 80k warranty. Got a second set using the pro-rated discount and had the same experience. Did an exhaustive research last fall and decided on the Michelins and they have been the best tires I've tried, definitely better in winter than the TripleTreds. We have some flexibility to stay off the roads during the worst of the snow but they were excellent in everything we encountered - the beginnings and ends of storms, partially plowed, light snow, a bit of ice, slush. This was the first winter I didn't have to make multiple attempts to get up our steep driveway when it had some snow on it. If we had to go out in the midst of storms I'd get dedicated snow tires.
    The Michelins have also been great in every other way - comfortable, quiet, handle well. The only thing I can't say is how they'll hold up but a key feature they promote and that has been tested in shaved tires simulating wear is they should retain their wet performance as the tread wears down.
    I bought my Prius Certified used with new Goodyear Fuel Max tires on it and have about 10k miles on them. Those tires are pretty scary in the little bit of snow I've gotten caught in. I will definitely replace them with the Michelins, probably well before they're very worn.
  16. Stevewoods
    Stevewoods Senior Member
    647
    986
    Seattle, WA
    If you can use any of the tires they sell -- and if ordering tires "through the mail" does not scare you (it does me, I would never do it), you might be interested in the deal below.
    I HAVE purchased tires directly from the Discount Tire brick and mortar stores and have been highly satisfied....but I just am uncomfortable with the whole shipping thing...
    tires, wheels items in Discount Tire Direct store on eBay!
    $100 off purchase over $400, free ship and stackable with other rebates
  17. Gandolf989
    Gandolf989 Junior Member
    34
    I just bought four Yokohama Avid Ascends from Tirerack. They work well on wet roads so far. They seem like they have an aggressive tread that may work for snow. But I use Blizzaks for winter which work really well. I did not have any issue getting the tires delivered. It took about 4 days for me.
  18. Intimate
    Intimate New Member
    22
    Pensacola
    Any recommendations for someone in Florida? I just get a lot of rain this time of year.
  19. Sue_CT
    Connecticut
  20. Sue_CT
    Connecticut
    GREAT, Thank you!
    #20 Sue_CT, Apr 23, 2015
