Replacement Underbody Battery Wiring Harness Guard?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BobThePrius, Mar 16, 2024.
  1. BobThePrius
    BobThePrius Junior Member
    22
    Michigan
    Hey everyone,
    After driving through some ice and snow on the highway, the plastic guard covering the traction and 12v battery was badly damaged. I have tried to find replacement, but the only thing resembling a part number was 45656-OW which has yielded no results. I patched it temporarily but would like to find a more permanent solution.
    The closest I have come is listings for whole wiring harness on ebay, I circled the portion in question :
    Any ideas on where to find this part online, or is the best place to go a junk yard?
    Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    8,920
    1,553
    Durham NC
    Yeah up in Michigan probably be pretty easy to find I don't know if that will easily come off that wiring harness You may just take the whole harness I don't know if that plastic unclips or if the wires just slide through or exactly what goes on I guess these are the wires that some people have had to replace that can go bad I go from the HV battery to the back of the inverter or something I guess the 12 volt is in there too Not really sure.
