Replacing A/C low pressure hose
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by goku9384, May 12, 2016.
  1. goku9384
    goku9384 Member
    47
    37
    My low pressure hose got a hole in it and now my A/C only blows warm air due to the leaked refrigerant. Anyone know how remove the hose at the connections as it is not using standard steel hose clamps. Thanks.
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    I haven't seen "standard steel hose clamps" on A/C lines in... decades?
  3. Patrick Wong
    18,200
    6,493
    The Toyota repair manual suggests use of a special service tool, 09870-00015. I suggest you subscribe to techinfo.toyota.com to obtain info about how to remove the fittings.
  4. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
  5. goku9384
    goku9384 Member
    47
    37
    Is that tool just used to remove the crimp from the rubber hose fitting area?
  6. goku9384
    goku9384 Member
    47
    37
  7. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    While it is possible to replace just the rubber hose portion of the A/C line, it is probably not worth the added trouble. Normally, the whole assembly is replaced. If your Prius is a 2004-2009, the one in the eBay link will not work.
