replacing a fuel filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joe350gt, Mar 25, 2007.
  1. joe350gt
    joe350gt It's too windy here...
    40
    38
    Wichita, Ks.
    Hey all,
    I've just turned over 62K on my '05 and on my other cars I've always had my mechanix put in a new fuel filter periodically. Is this an easy (and good idea) preventative maint. item to do on a Prius? Is it DIY-able? I'm also thinking about having the transaxle fluid drained and replaced. Is the Toyota WS fluid the only one to use or are there others that would be ok to use? I'm putting big miles on my car and would like to do some stuff to extend the life of it. I also just added a K&N air filter today. Anyone else put one in and if so did you see any mileage/power increases?
    Thanks in advance,
    Joe
  2. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    it's not really possible, actually. the fuel filter is integrated with the fuel tank. there is no need to change it anyway. no worries!
    you definitely want to put WS back into the trans when you drain it.
  3. joe350gt
    40
    38
    Wichita, Ks.
    Thanx Galaxee,
    I can sleep easy tonight!!! I'll get some of the WS for sure. I read on some other post that it's basically a grain and fill deal. I'll find that post and go from there.
    Thanx again!!
    Joe
    <div class='quotetop'>QUOTE(galaxee @ Mar 25 2007, 10:32 PM) [snapback]412114[/snapback]</div>
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Doesn't the grain sort of gum up the gears? :p
    Sorry, I just had to.
  5. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    He meant to type 'brain and fill', Bill. Krill. Whatever.
  6. Bill Merchant
    4,096
    85
    Thanks for the clarification, GAS. :p
