Replacing: Coolant Fan Motor
Discussion in 'Prius c Technical Discussion' started by RobAustin, Oct 8, 2019.
  1. RobAustin
    RobAustin Member
    104
    51
    Austin, tx
    2012 Prius C
    I am in the process of swapping out the fan shroud and motor assembly with a used one from salvage. (LQK)
    Do I need to remove the front bumper or are there any special instructions to complete the repair?
    Thank you!
    Rob
  2. RobAustin
    RobAustin Member
    104
    51
    Austin, tx
    Half-way through the process I'm realizing I might need to pull the radiator core to access the fan shrouding.
    Is there a better way?
    Rob
  3. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    No direct experience, sorry.
    On lots of other recent japanese cars it is normal to remove the radiator and fan assembly as a unit.
  4. RobAustin
    RobAustin Member
    104
    51
    Austin, tx
    Thank you Leadfoot.
    I am told by another forum member that it is a simple straight forward removal that Does Not require taking the front number off.
    I've hit a snag with removing the radiator hoses, (they seem stuck after 7 years of service). And wanted to pause and double check first.
    Rob
  5. ChapmanF
    15,615
    There's a little tool that can help with stubborn hose removal, looks kind of like a bent-over ice pick, so you can kind of go around under the edge of the hose with it, unstick it from the metal nipple.
