Replacing Driver & Passenger Seats
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Future, Mar 23, 2010.
  1. Future
    Future Your new best friend
    I'm considering replacing the driver & passenger seats with racing seats in my 2007 Prius. Has anyone here replaced the seats or know anyone who has. I'm curious as to how I could replace the seats and keep the occupancy sensor things in the seats working. I don't know much about seats, but I'm assuming I may have to get replacements brackets for the new seats. If anyone has any info that could help me please share. Also, I'm looking for the dimensions of the stock seat if anybody knows this info (I can't read a tape measure).
    Thanks,
    Future
    Sezy likes this.
  2. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Your driver's seat has a seat position sensor and airbag. The passenger seat has an airbag and occupant detection ECU (don't know if it has position sensor).
    There's guy who put a pair of volvo front seats in but I don't know all of how he pulled it off.
    I got a quote from an upholsterer who said he's put a number of Recaro seats in Gen2 Prius'. I didn't get details, but I swear he said they bolt the airbag onto the side of the Recaro seat frame (imagine, has explosive igniter inside, bolted to side of your seat, great).
    Anything is possible.
    Not sure why you'd want racing seats in a Prius. It's a Prius after all. Feeling up too high in the car? That's because seat is fixed 2" higher than if it had a height adjuster put all the way down. No height adjustment and lack of telescopic steering wheel ruin decent ergonomics for many Gen2 drivers. Plus, it's small, narrow seat.
    Something more racy at low cost would be like a ....
    Mazdaspeed 3 hatchback or just basic Mazda 3
  3. a_gray_prius
    2,927
    782
    IL
    You could probably do it but you'd most definitely lose the side airbags. It's likely that you would have to fabricate your own seat rails and mounts to adapt to like a Sparco or a Bride.
  4. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    Recaro also makes a seat with its own side airbag.
  5. Future
    Thanks for the replies so far. I was unaware that the airbags were within the seats themselves. I wanted to put the new seats in because they are more comfortable and have the color scheme I want. It would actually be cheaper to buy the (cheap) new seats that I want than to buy decent seat covers for the stock seats with the color scheme that I want. But I suppose the whole airbag thing complicates the situation more :(
  6. a_gray_prius
    2,927
    782
    IL
    The problem with cheap aftermarket seats is typically their poor survivability in crash situations. I'd bet money that if the seats you're thinking about using are cheaper than seat covers, crash/safety testing was likely not even on the manufacturers' set of engineering tasks.
  7. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Airbag is the black thing bolted to side of Prius seat frame. It had warning signs in 4 languages on it :)
    I would think the seat position sensors, airbags and passenger occupant detection ECU complicate things a whole lot. That and securely bolting racing seats in the car, interfacing wiring harnesses, mating seat belt buckles to seat latches.
    If you're not too tall, you might be able to improves things with some seat foam shaving (I know a few things about that), then covers to give the look you want. Lot easier than bolting aftermarket seats. A Prius seat bottom foam cushion is $200.
    Plus, if you did put in aftermarket seats, would need to be sure you can easily put the car back to stock or else cannot trade car in and doubt anyone would buy the car - too much liability.
    One more thing - it's not just the seat to worry about, it's the steering wheel too. Say you put a racing seat in that sits very low to the floor. You may be screwed because the steering wheel may not be designed to accomodate. Just saying.
    Some performance shops might know more about sport seats in a Prius.
  8. Future
    Thanks for the advice cycledrum. I had read you thread about you changing your drivers seat. It was very informative and I really liked the pictures.
  9. PaulRivers
    PaulRivers Member
    100
    MN
    I know this thread is a little old (but still this year), but I keep running across it in my searches which is why I wanted to update it.
    I called Recaro directly and they said they make a seat with a side airbag, but don't sell it in the US for liability reasons. I also found out more info about the "losing the side airbag" thing, if you're interested (there's actually 2 side airbags, you only lose 1 and good side bolsters may or may not make up for that one):
    http://priuschat.com/forums/gen-ii-...t-i-offer-some-side-airbag-clarification.html
  10. priusrick
    priusrick Member
    257
    40
    I have to get different seats, I'm having bad back problems now. What, have we figured out, are the direct replacement options?
    HTC One V ? 2
  11. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    An extra inch of foam (side bolster) isn't going to mean squat when you're t-boned at 50 mph, especially if you're only buckled into a 3 point stock seat belt. There's no making up for the lost airbag, unless you're talking about a containment seat...
  12. sidecar
    sidecar Member
    342
    44
    Australia
    just a thought, but if you are looking for seats to replace the stock Prius equipment (and why not) perhaps something within what Toyota offer on their other models is more worthwhile. There are bound to be more similarities that would ease the transition of fitting and hardware issues such as air-bags.
    Perhaps something from the Celica range or something like that .....
  13. priusrick
    priusrick Member
    257
    40
    I don't know what comfort is, camaro I rented had wonderful seats
    HTC One V ? 2
