Replacing EGR System Coolant After Full Cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by theheapstoe, Apr 2, 2019.
  1. theheapstoe
    theheapstoe Junior Member
    26
    Coulterville, CA
    Hey there,
    I just went through the cleaning process for the EGR valve and cooler today. I did the best I could with limited time and it did turn out to be an all day project, but in the end, the bumping is gone and my car is in much better shape.
    My concern is the lost fluid from the cooler. No one has mention how to replace this fluid in any of the tutorials that I can find. Is it a closed system? Or does it pull from one of the two reservoirs? Any help with how to replace the lost fluid and bleed the air so I don't over-heat my system?
    Thanks in advance. This forum has been a lifesaver on more than one occasion.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    It pulls from the engine coolant loop;).
    So make that’s to the line and you’re good to go :).
    Good luck and keep us posted (y).
    NutzAboutBolts likes this.
  3. theheapstoe
    26
    Coulterville, CA
    Thank you so much! When things looked okay after the cleaning, I assumed thatst where it came from. Unfortunately, now I'm leaking about 5 quarts every 1000 miles. Yes, you read that right, but I'll ask about that in a different thread.
  4. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Head gasket issue?
    Any dash lights?
  5. theheapstoe
    26
    Coulterville, CA
    No dash lights. That stay on. I get that low oil pressure warning every once in awhile on a hard turn, but that's even with me topping the oil off every time I fill up gas. Also, in another forum they mentioned the piston ring replacement...is that worth it?
  6. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    You have a serious oil consumption issue and this was occurring prior to the egr cleanse?
    What was consumption rate prior?
    How often were you topping up prior to the egr cleanse?
    The egr circuit cleanse does not solve the oil consumption, it just helps ensure the air flow isn’t impeded.
    No miracles there.
    Grit likes this.
  7. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    @theheapstoe ?
  8. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Have you checked for leaks around reservoir and cables yet?
  9. Mendel Leisk
    38,726
    How many miles on it?
    What does coolant leaking into cylinders result in, at the tail pipe? White smoke, IIRC?
    Remove the spark plugs and run an inspection camera cable in, look for coolant. Cylinders one and two (standing at the front, left to right) seem to be the most leak prone.
  10. theheapstoe
    26
    Coulterville, CA
    Oil consumption wasn't bad, but I did have the light blink at me once and I kept oil in the car since that time. Definite HUGE increase after the EGR cleaning.
    I didn't measure the rate before because it wasn't outside of normal compared to my last prius.
    I rarely had to add any oil before that point, just during a road trip to UT from AZ.
  11. theheapstoe
    26
    Coulterville, CA
    Oh, the coolant wasn't leaking, the OIL leaked into the engine more.
  12. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    o_O
