Replacing engine oil dipstick?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Toyotally04, Sep 5, 2020.
  1. Toyotally04
    Toyotally04 Member
    128
    16
    SoCal.
    Hello y'all,
    What would I need to look for to replace a 2gen motor oil dipstick?
    Physical specs, brand, retail availability (i.e., where can I buy it?)
    Mine is varnished badly.
    Thanks,
    TTLLY04
    49,456
    you can go to any toyota parts on line with the model year, or call a dealer. ebay might have good used or salvage yards.
    Toyotally04 likes this.
  3. JC91006
    16,482
    8,397
    You don't need to buy a new one, just clean it with some acetone. Maybe you can try some gasoline or strong chemical. Use a little elbow grease and it should become cleaner (to an acceptable appearance).
    Don't spend too much time on it, because the real problem would be the entire engine looking like your dipstick, and you can't clean it
    Mendel Leisk and Raytheeagle like this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    If the dipstick is that varnished so is the motor.
    Steel wool can clean the DS right up.
    If motor that varnished it probably has clogged piston rings and eats oil bad. Keep an eye on the engine oil loss.
    M in KC likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,909
    Columbia, SC
    Buy a piece of 1000 grit sandpaper?
    Use some nail polish remover and a rag to clean it?
    5 bucks for a dipstick from a salvage yard, but it's likely to be discolored also, since 99% are.
  6. Toyotally04
    Toyotally04 Member
    128
    16
    SoCal.
    Can't wipe the stain off.
    Is it always called varnish and does it always indicate potential engine problems in any circumstances?
  7. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    The important part between the dimples looks clean enough, why are you stressing about it?
  8. TMR-JWAP
    6,225
    5,909
    Columbia, SC
    Other than a brand new car, every vehicle I've owned has had tan/brown discoloration on the dipstick shaft. I don't think it's anything to worry about.
  9. bisco
    49,456
    it used to be called varnish in woodworking class
    edthefox5 likes this.
  10. edthefox5
    10,096
    4,805
    Clearwater, Florida
    If its baked onto the dipstick which is basically sitting in a moving pool of oil you can only imagine how bad the inside of the engine is.
    Its baked on shitty oil high quality synthetic oil does not bake on to the metal the higher the quality oil it is the less it bakes on.
    I wont bore you with acronyms.
    Lets call it BOSO.
    Your looking at a high mile OCI with really crappy dino oil. Toyota engines that already suffer from clogging rings will not enjoy that.
    Its not a stretch to imagine its a high oil using engine.
    But its dealer maintained so go figure. Its almost like they don't care.
  11. Richard2005
    Richard2005 Member
    159
    69
    Australia
    I used Autosol 'Metal Life Saver' ... removed the varnish easily and without damaging he surface in anyway. Looks brand new.
  12. TMR-JWAP
    6,225
    5,909
    Columbia, SC
    Grab a paper towel, splash on a little nail polish remover and have at it. Takes it right off....total cost about 10 cents
    Toyotally04 and Mendel Leisk like this.
