Replacing factory Homelink mirror with the frameless version?
Discussion in 'Prime Accessories and Modifications' started by Darien Day, Dec 23, 2021.
  1. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
  2. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
  3. BChoAss
    BChoAss Junior Member
    34
    22
    CA
    2019 Prius Prime
  4. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
  5. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    In case anyone is interested, here are pictures of the factory HomeLink mirror that comes with the 2022 Prime Limited:
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    It looks like the harness goes into the arm that the mirror is attached to then into the mirror's housing.
    There's a person on the RAV4World forums that says he can compare the connector from that Toyota wired, frameless version to see if the connectors and wiring are the same.
  6. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    Switched or constant power is available from the harnesses on the mounting plate. I did not ring out the wires when installing my dash cam, as the company provided the necessary harness adapter. The cover is easily removable and, once off, will allow access to check voltage states. Find what ya' need then splice to it... easy-peeezy. But WHY go through all this to merely replace an existing Home-Link mirror with one sans-front buttons?
  7. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Not going to if I have to splice or run new wires. That's why I'm posting all of this. I'm hoping someone else has that frame-less mirror and can verify whether the connectors are the same (so I can use the one from the stock mirror).
  8. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Swapped the factory mirror out with this frameless one. It was plug-and-play.
    Canvasback likes this.
