Replacing Fender Liner - Question Wheel/Raise?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by surpriuse1, Oct 24, 2022.
  1. surpriuse1
    surpriuse1 New Member
    Los Angles
    Hello, I have obtained a new fender liner for my 2012 Prius plug in. Does anyone know if I can replace it without having to jack the car up and take the wheel off?
    Thanks so much!
  2. Mendel Leisk
    38,657
    You definitely need the wheel off. Also, there’s one fastener near the back/middle, has a plastic embed in wheel well, almost impossible to remove without destroying.
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,289
    336
    2013 Prius Plug-in
    im doing mine now with the wheel on.. attaching it to the metal engine splash shield
  4. Mendel Leisk
    38,657
    There are a lot of push-in plastic fasteners around the wheel well interior IIRC. Not sure half off them would be reachable with wheel installed, or even if they are, why not make it easier?
  5. surpriuse1
    Los Angles
    Thanks! Can confirm, forgot I posted this and did it with the wheel on. It is doable.
  6. BiomedO1
    BiomedO1 Senior Member
    1,446
    790
    SacTown, Ca
    Yes, it is doable - but your turning a 5 minute job into a half hour or an hour job. I'm also assuming that your smart enough to rotate the steering wheel all the way in one direction to work on the front liner fasteners, then turn the wheel all the way in the opposite direction, to get to the rear fasteners.
    Anyone attempting this, should get an extra screw and a couple of push-in fasteners. In case a few break-off during extraction. The older the car, the more brittle the plastic becomes.
    Just my 2 cents..
    #6 BiomedO1, Dec 17, 2022
  7. rjparker
    rjparker Tu Humilde Sirviente
    7,919
    4,685
    Texas Hill Country
    Plus the aftermarket liners are flimsy and the fit is marginal. But better than a torn up liner. You probably don't have notifications set. They are off by default on this site.
