Replacing front springs, what is the difference between the two models?
Discussion in 'Generation 1 Prius Discussion' started by sheepe, Dec 27, 2014.
  1. sheepe
    sheepe Junior Member
    Ohio?
    2001 Prius
  2. ChapmanF
    15,464
    It's the free length in millimeters, which would affect the resulting ride height, but I'm not sure how to determine which one is best. I'm assuming your reason for replacing it is wear or damage to the original, so measuring the old one might not help. Are you planning to replace one side or both?
    Have you tried asking at a dealer and supplying your VIN?
    -Chap
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    Whenever you replace front struts, be it OEM or KYB the upper and lower rubbers (where the top and bottom of the spring contact the strut) are almost always trashed. The aftermarket ones don't fit well so you should order OEM rubbers, and you may need upper strut mounts too. Dealers don't usually stock the rubbers, so plan accordingly.
