Replacing Inverter on 2001 Prius
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Patricia2012, Apr 1, 2012.
  1. Patricia2012
    Patricia2012 New Member
    Gainesville, TX
    2001 Prius
    My Hybrid System Warning Light is on. The dealership already reset it, but the light came back on. The dealer says "they think the inverter needs replacing." How do I know if that's correct? My car still starts.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You should ask this in the correct sub forum. When you do state the maintenance codes read out by your dealer.
    JeffD
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Assuming that this thread gets moved, don't buy a new inverter. Used ones are much cheaper.
  4. Joe1234
    Joe1234 New Member
    2002 Prius
    I
    Hi I had the same problem. What I discovered is that the inverter cooling pump was not working. To check this simply open the invereter cooling resivior you should see some sort of turbulence when the pump is working.
