replacing light bulb on 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenGuy33, Aug 8, 2011.
  1. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    Are there any videos on the best way to replace a headlight light bulb (on passenger side)?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It is hard! I had to remove the coolant tank to do it.
  3. GreenGuy33
    534
    29
    Rhode Island
    Thanks! Yea, I removed the coolant tank, replaced the bulb, replaced the coolant tank. Total time = 10-15 minutes.
    I paid $14.99 for the Sylvania replacement bulb at Auto Zone. (not bad compared to paying a Toyota dealership to do it).
    How much would a dealership charge?
  4. RRxing
    RRxing Senior Member
    2,548
    1,825
    NEPA
    Section 4-3 of the owner's manual explains how to do it. For the passenger side, it says to remove the bolt and unclip the engine coolant reservoir hose, then lift up the air cleaner inlet duct to gain access to the bulb assembly. No coolant tank removal necessary.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Yeah, I was wondering why people are removing the coolant tank. Do people not read the manual?
  6. RRxing
    2,548
    1,825
    NEPA
    Apparently not...:confused:
  7. katiesdad7
    katiesdad7 Member
    172
    25
    Stuart, FL
    You don't have to remove it you just have to move it out of the way. Don't disconnect any lines and just move it up and out of the way.
  8. GreenGuy33
    534
    29
    Rhode Island
    I followed the directions on the manual and removed the 2 screws on the coolant tank in order to get at the light bulb. If I didn't remove the screws, I couldn't move the tank out of the way to get my hand in there.
  9. GreenGuy33
    534
    29
    Rhode Island
    What a bunch of condescending jackasses!
    2 people like this.
  10. RRxing
    2,548
    1,825
    NEPA
    Not meant to be condescending at all, but since your initial post never indicated that you looked at the manual and instead followed spiderman's advice, I commented with the manual's information. If you had to (re)move the coolant tank in order to change the bulb, and you were successful, then congratulations. The manual doesn't require it, that's all.
  11. almypal26
    almypal26 Member
    101
    So Cal
    Can't we all just get along? R. King:)
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    If you merely unclipped the hose and moved the inlet duct out of the way as shown in the manual, you didn't "remove the coolant tank."
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It was all my fault... I mentioned remove the tank when I should have said move the tank. I never actually "removed" the tank from the car, just loosen and moved off to the side.
    2 people like this.
  14. perry1023
    perry1023 Junior Member
    Orange County, CA
    it is important to realize that the bulb installs from the outside to the inside. while facing the headlamp the bulb needs to swing OUT 45degrees and swing IN . as far as removing anything loosen and remove the bracket located in front near the windshield wiper fluid. this will allow you to reach in and under. I found this to be the most frustrating lightbulb change ever.
  15. whsauto12
    whsauto12 Junior Member
    Statesville, North Carolina
    2018 Prius Prime
    Most annoying headlamp change is the HID lamps on the GenII. By the way, Toyota was replacing the HID lamps under warranty. I had two go out at 40k. I complained to Toyota and they gave me credit for the bulbs, not any labor to replace them.
  16. LatteDrinkingLiberal
    LatteDrinkingLiberal Junior Member
    65
    Marietta, GA
    I had both low beams out and a parking light on my 2010. I went to Auto Zone and bought the three bulbs for $40 total. The clerk said he would "pop the bulbs in" for me. He was able to fit his hand into the passenger side without moving or removing anything. He used gloves on his hands and bulb grease on the bulbs. Ten minutes later I was on my way.
