Replacing OEM NanoEnergy with Dunlop Blu Sport Response
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by raspy, Nov 2, 2017.
  1. raspy
    raspy Senior Member
    438
    699
    London, UK
    After 14k miles, my factory Toyo NanoEnergy tyres were worn on the front, and one of the back ones got a nail in it, and curious if another brand could be quieter, I decided to replace all four tyres today with Dunlop Blu SportResponse. I've only driven up to 30mph so far, but first impressions are that they are not any quieter, and the ride seems less supple than the Toyos. According to EU tyre label, they have one of the lowest noise ratings at 68db. They were cheap too (50 pounds each or 65 US Dollars) including fitting. The guy in the tyre shop showed me a tyre for a BMW X6 which was 360 pounds (468 US Dollars) - I'm glad I drive a Gen 4 with skinny tyres!
    Will monitor to see how MPG changes with these tyres. It rains a lot here in England and apparently these Dunlops are supposed to be superior than other tyres when it comes to reducing stopping distances when braking in wet conditions.
    RCO likes this.
  2. Matthew Griffiths
    Matthew Griffiths Junior Member
    Les Bossons Haute Savoie
    Active
    I had them on my old prius. I really liked them for the quiet and grip etc.
    I read somewhere about taxi drivers getting annoyed because they wear out quickly and can easily get flat tyres.
    I thought they were great. I did get a flat tyre in the side wall a few months ago. But fortunately they were due replacement anyways.
    RCO and raspy like this.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    When my Toyos wear out, I'm gonna go with Ecopias again. I had good experiences with them on my Gen 2.
    pilotgrrl, RCO and krmcg like this.
  4. krmcg
    2,592
    2,390
    Whittier, CA
    Me too
    pilotgrrl likes this.
  5. raspy
    raspy Senior Member
    438
    699
    London, UK
    Did one of my normal early morning drives into London this morning, and was surprised to barely get 60mpg (UK) according to the dash. I did the exact same drive last week when I had the Toyos on, and got 80mpg. I consistently got 75-85mpg on that drive in the last few months, sometimes getting above 90mpg in the summer.
    There are two factors that changed since last week.
    1. Replaced my worn OEM Toyos with the Dunlops
    2. Temp was 10C (50F) last week, and was 5C (41F) this morning
    Now going from 80mpg to 60mpg is a 25% drop.
    I appreciate that I need to be comparing tank to tank, which I will do over time, but doing some research on the internet, it seems that others who have put on new tyres have noticed a drop in mpg, with some explaining it as the brand new tyre having a larger diameter because of the 8mm of tread or the tyres need to be broken in for a few thousand miles before you can get up to your normal mpg. Let's wait and see.
    I did check the tyre pressures at lunchtime today and they were 1-2 psi down from what I was running with the Toyos which was 36 front/35 rear. So I pumped them up and went on the motorway for drive. The ride seems more Germanic than the Toyos (firmer but less supple) and I noticed the car was a lot more controlled in terms of bounce at high speed (the Toyos provided a Cadillac like ride) It may just be me but the Dunlops feels less 'sticky' when going round bends. They grip well but don't seem to stick like glue to the road like the Toyos did.
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Temperature has dropped in Cornwall as well with this temporary Arctic air mass a new my observed daily fuel has dropped to ~60mpg from ~70 mpg. Temperature is low teens Celsius, down from mid teens and no new tyres! (n)
    raspy likes this.
  7. raspy
    raspy Senior Member
    438
    699
    London, UK
    Heavy rain in London tonight. Driving at 30mph, another driver tried to change lanes into my lane without looking in their mirror. I had to slam on the brakes to avoid hitting him as I was in the inside lane and had no room to swerve.
    I genuinely expected my car would slide given how much surface water was on the road and how quickly I needed to stop. The car came to a stop very rapidly without any fuss or drama. I put it down to my new tyres which were rated very highly for performance in the wet.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    No way! You underestimate your own reactions and immense skill. :cool:
    kithmo and raspy like this.
  9. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    I suspect the lower temperature has made the biggest difference to your mpg. My journey to work of just over 7 miles yielded a little over 63mpg this morning with temp at 4oC. Usually i get over 80mpg, sometimes much more in the higher temperatures.
    Interestingly my EV ratio was 62% which is only a little less than the more usual 64-67%
    This is my first Prius and was expecting the range to drop during the colder months, just like I experienced in my Zoe EV so it isnt a surprise :)
    RCO likes this.
  10. raspy
    raspy Senior Member
    438
    699
    London, UK
    Yes, you are probably right. It happened last autumn too, I've just gotten used to summer driving and high mpgs.
    The Dunlops do seem quieter than the Toyos across a variety of road surfaces, so less tyre noise now, which makes the engine seem noisier when accelerating!!
    Harters and RCO like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    The new tyres grip will probably improve after 200-300 miles when they've bedded in. I remember in the 70s having some Dunlop SP tyres which were the best available at the time for wet weather grip and they were phenomenal compared to the Michelin Xs and other offerings at the time.
    FWIW, The UK noise ratings are actually drive-by noise, in car (road) noise can vary wildly car to car.
    Harters, RCO and raspy like this.
