Replacing Old FOB Case With New Empty FOB Case
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by flyer201, Feb 24, 2018.
  1. flyer201
    flyer201 New Member
    Sydney, Australia
    i-Tech
    I though I might post my experience with this because I've not found anything specifically on line in a cursory search. While it may seem dead simple I got tripped up and spent a day trying to figure out something that in the end was quite obvious....but, only if you know about it. I didn't.
    My wife's 2006 I-tech (Australia) Prius original keys were in terrible condition. One had a split case and was held together with a rubber band, and the other had a destroyed "lock" key on the case. Fortunately the circuit board was fine if you could find the switch with a finger nail. There are numerous sources for empty FOB cases such as Ebay, Amazon, etc. They range in price from $9.00-$18.00.
    Getting the electronics board out of the already split FOB was rather easy. It seems to be lightly glued in place and came away with little effort. It fit easily into the new FOB case. Opening the un-split case required quite a bit of work with a straight edged razor blade but was finally successful. After reassembly all seemed in order and the door opening/locking function worked fine. But, nothing would work trying to start the car! What I have not mentioned is that I also needed to replace the 12 volt battery at the same time as the case replacements. This certainly made the ensuing detective work more of a challenge because I incorrectly assumed that the FOB starting issues were more related to having had all power removed from the car.
    Long story short (!) there is another part of the original FOB besides the electronics board that must be transferred to the new key. This is the "transponder" and it is black and blends right into the old case. It does have a serial number stamped onto it. It is located just above the battery holder and looks like an elongated triangle...much longer than tall. It is glued into a similar shaped bounded plastic slot. This must be pried away and placed in the new key FOB to allow engine start! Before I discovered this I had tried everything....disconnecting and recharging the 12 volt battery, Locking the car with a window open and taking the FOB far away and then unlocking from the inside, etc. Finally as a last ditch effort I put the old - now empty of electronics and battery - FOB into the dash and amazingly the car instantly started. That was the clue, of course, that I'd missed a vital step. This was a very close call because the FOB replacement had taken place several days earlier and I specifically told my wife not to throw any parts away. She did anyway and I had to fish the old FOBs from under a heap of garbage. All I can say is thank god there hadn't been a trash pickup!
  2. cjannes
    cjannes Junior Member
    I just ordered a replacement fob case a few days ago from Amazon. It says right in the listing to be sure to move the circuit board AND the chip over to the new fob. Sounds like other may have done the same thing you did and so the Amazon seller updated the listing.
  3. ChapmanF
    15,886
    I don't think it should be that much work (though maybe it is for a Gen 2, I don't have one to look at right now). On a Gen 3 fob, there's a little slot located in the seam at one end, just the shape of the end of the mechanical key blade. You don't normally see it because the mechanical key head conceals it. Slip the key out, put the end in the slot, twist, pop! case is open.
    Maybe Gen 2 didn't have that ... or maybe the aftermarket case replacements don't.
    -Chap
  4. cjannes
    I just swapped mine. The circuit board is removed from the bottom half of the case and the RFID chip is removed from the top half of the case. The RFID chip is small and black (same color are the rest of the fob), so I see how easy it could be to miss it. Also, as the OP mentioned, the doors will lock/unlock without the RFID chip, so it could be tricky to troubleshoot for the person who missed moving the RFID chip over.
  5. flyer201
    flyer201 New Member
    Sydney, Australia
    i-Tech
    The 2 cases I ordered came with no instructions at all. The RFID chip is certainly visible, but rather easy to ignore.
  6. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    The Gen2 keyfob case is glued together. The easiest way to separate the two sides is to insert needle nose pliers into the mechanical key space and spread it open. The click together replacement cases are a real improvement.
