Replacing PCV valve on 2007
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fikey13, Apr 11, 2012.
  1. fikey13
    fikey13 Junior Member
    virginia
    I see that this has been covered here on different models with differing advice. What exactly has to be removed on the 2007 to get to it?
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Please follow these instructions exactly:Search
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    That depends.
    DIY or do you just want to know what the mechanic will have to do to replace it?
    If DIY, you will need to get the service manual. It's available in pdfs in chapters on the internet (I won't tell you how to get them, that's your job).
    Once you get the service manual, the procedure looks fairly easy. Basically, it requires removing the air filter housing and the wiring harness for the ignition coils and fuel injectors in addition to a few other things. I plan on replacing/inspecting the PCV myself sometime this summer.
    BTW, Toyota refers to it as a ventilation valve in the service manual. You will find the procedure in the emission chapter.
  4. Patrick Wong
    18,200
    6,479
    All 2G are essentially the same with regards to the engine, so to the extent you see different advice regarding PCV valve access, that is based upon personal preference.
    At minimum you will need to remove the wiring harness that runs across the valve cover, for access to the valve. You may find that your access is substantially improved by removing the cowl that contains the windshield wiper motor. That will also give you a chance to get rid of whatever leaves and other gunk have accumulated in the cowl area.
  5. cnschult
    cnschult Active Member
    772
    96
    Michigan
    here's the procedure for generation II:
    http://priuschat.com/forums/knowledge-base-articles-discussion/56852-pcv-replacement-how-photos.html
    it looks like a lot of work so good luck, I believe other posts recommend doing it around 110,000 miles as it is basically the same procedure as replacing your spark plugs. If you absolutely insist on doing it before the iridium spark plugs are due for replacement, it is recommended to carefully remove the spark plugs, anti-seize the threads, then put them back so that when the time comes to do the spark plug it will be much, much easier.
  6. Hybrid_Tom
    Hybrid_Tom Junior Member
    83
    Houston, TX
    Here is a photo of my old 2006 engine, which is the same as your 2007. The PCV valve is shown on the upper right side of the valve cover, attaching to the breather hose. That is what you will be looking for, when you get down to it. You will need a 19 mm wrench to remove it.
  7. jadziasman
    1,355
    487
    District 6
    The procedure to remove the pcv valve (with photos) is overkill. The major obstruction is the ignition coil and fuel injector wiring harness.
    Why do more work than you have to?
    Get the service manual.
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Using a 12 point 19mm BOX end wrench is the key. Threadlocker was applied at the factory and makes it very stubborn. DO NOT USE A CRESCENT WRENCH.
  9. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    I did my PCV yesterday, what a pain! I did not help that it was 95 degrees.
