Replacing Prius C battery.
Discussion in 'Prius c Main Forum' started by 4priusowner, Mar 28, 2022.
  1. 4priusowner
    4priusowner Junior Member
    69
    Hi , have friend that is that a dead hybrid battery on his 2013 Prius C and is thinking about changing to the new Lithium pack. Just wondering if it is recommended to change the battery ECU also and if so are they the same for all years or did they change, so he might be able to find one.on Ebay. Or if anyone can recommend a good place to purchase a new or remanufactured ECU, that would be much appreciated. Thanks in advance
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Those pack are rare and don't require a new ecu
  3. John in Vermont
    John in Vermont Junior Member
    35
    Rochester, Vermont
    2018 Prius c
    The original battery lasted 9 years, an original type replacement battery should last just as long, at which point the car is 18 years old. What could possibly be gained by spending far more on a lithium battery that probably won't last any longer?
  4. 4priusowner
    69
  5. 4priusowner
    69
    Actually the lithium battery for that car is only 1550.00 new which is far less and a lot more powerful than the original replacement
  6. Ancel Bhagwandeen
    Ancel Bhagwandeen Junior Member
    47
    31
    Caribbean
    That lithium battery supplier lists everything as sold out......A bad sign. They clearly can't run a biz.
  7. Pri3C
    Pri3C Active Member
    180
    127
    Midwest
    2014 Prius c
    I’m not sure how them selling out is a sign of them not being able to run a business. They’re a smaller business, and they get new shipments in regularly. I think the fact that they managed to successfully launch Project Lithium and keep new shipments coming during the pandemic is a testament to them knowing how to run their operations. More importantly, they tested and researched the battery packs for quite some time, and they seem to be doing well for customers so far.
    Anyway, I have a question about the OEM hybrid battery: if one purchases an OEM replacement, is installing it just a matter of removing the old and plugging in the new one?
  8. tankyuong
    1,555
    660
    Central MO
    there are
    some parts that need to be removed to put on the new batt
    Pri3C likes this.
  9. ilker_t
    ilker_t New Member
    usa
    What are those parts?
  10. Mendel Leisk
    38,875
    The ones present on your current battery, and missing from the new one.
    It doesn't hurt to take pics before removing anything from your current battery, and the new one as well, help keep straight wire routing and so on.
    This is a Camry battery transfer, but worth a watch, in particular the transfer of parts:
  11. tankyuong
    1,555
    660
    Central MO
    modules
