replacing rear lens cover - how to?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusownerfromCanada, May 8, 2020.
  1. PriusownerfromCanada
    Ontario, Canada
    Hi - I'm new here and need some advice. I'm attempting to replace a cracked rear lens on the passenger side of my 2012 PriusC. I purchased a replacement on line and am able to get the old lens cover off and remove the bulbs. Everything is good except I need to remove the circular connector (circled in the photo) from the original and install it in the new one. Do I just rotate it counterclockwise to remove - tried to do that by hand and it won't budge. I could use a screwdriver for leverage but I'm worried I will crack the plastic. Any advice would be appreciated!
  2. PriusownerfromCanada
    Ontario, Canada
    Figured it out myself - that round plastic thing is held in by the central Philips-head screw. Once the screw is removed there is an o-ring that keeps the round plastic thing from falling out. Need to pry it up around the edges (without damaging the o-ring seal) to get it to come free. The rest (twist in bulb housings and putting lens cover back on) was easy.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Beat me to it. First thing I saw was the screw! LoL
