Replacing rubber hoses due to age
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, Jul 21, 2019.
  1. kehyler
    kehyler Member
    84
    32
    blah
    Hi All,
    Not urgently, but its on the horizon. I'd like to replace many critical (defined as their failure would stop the car) rubber hoses soon on my 8 year old prius. One set I was thinking of was to start compiling the rubber hoses involved in the engine coolant system (they show some surface cracking at this point). Couple of questions:
    (1) Anyone know the PNs for the OEM hoses for the engine coolant tubes?
    (2) Any suggestions of other hoses to change while I am at it?
    Thanks!
    52,393
    how many miles on her? hoses on a prius seem to never get replaced
    Grit and Mendel Leisk like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I thought about doing them on our 2010 pre-emptively, but then said, meh;).
    Even though the hoses feel soft, they’re robust and are good for a long time(y).
    Grit and bisco like this.
    52,393
    if mendel hasn't done it, its not worth doing
    Tande, Ed Beaty, Grit and 1 other person like this.
  5. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    The garage queen does lead a pampered life;).
    Maybe @Mendel Leisk has thought about it:whistle:?
    I bet he won’t admit it though given the low miles or kms :p.
  6. Mendel Leisk
    41,908
    Never changed a coolant hose; cargo cult. :cool:
    Grit and Raytheeagle like this.
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    You’ve lapsed into sidewalk supervising:p.
    Ed Beaty, Grit and Mendel Leisk like this.
  8. Mendel Leisk
    41,908
    That might make it worthwhile
    Yes, is this a high mileage car? And does "blah" get pretty hot?
    This page has hose summary I think; scroll about halfway down for a second diagram with the myriad small ones:
    Radiator & Components for 2011 Toyota Prius | McGeorge Toyota Parts
    frodoz737 and kehyler like this.
  9. schmuber
    schmuber Member
    115
    85
    Georgia
    1. Disconnect both batteries
    2. Remove the air duct and wash/treat it separately
    3. Cover the throttle body
    4. Wash everything else with Simple Green or Dawn, rinse thoroughly
    5. Let it dry or blow dry it
    6. Spray 303 aerospace protectant on everything
    7. Put it back together
    8. Profit!
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    That’s it... I’m quitting my job to clean Prius hoses.
    Tande likes this.
  11. kehyler
    kehyler Member
    84
    32
    blah
    The miles (88k) to me don't matter much since I think rubber dry rots and therefore the age in years matters more.
  12. kehyler
    kehyler Member
    84
    32
    blah
    Thanks, I bookmarked that list!
    Mendel Leisk and frodoz737 like this.
  13. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    On an 8 year old car, I wouldn't worry about it. Even on 20 year old cars, I have never had to replace a hose other than a vacuum hose (they tend to brittle at the ends and get air leaks). Coolant hoses and the like are quite sturdy.
