replacing steering employ without buying horn?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Florida, May 10, 2017.
  1. Florida
    Florida Junior Member
    29
    Everything in my 2010 Prius III not Three looks brand new except the chrome on the steering wheel emblem is worn. Can I pop/pry that out with a thin screw driver:
    1) without damage plastic around it
    2) without activating the steering air bag?
    3) can you buy that small oval emblem at the dealer?
    Thanks
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    its part of the airbag
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
  4. xliderider
    8,056
    3,223
    Honolulu, HI
    Also, please edit your thread title. Should be emblem, not employ. Have to love autocorrect. ;)
  5. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    How is the old one removed?
  6. Florida
    29
    Thanks for the link to buy the emblem. The only trouble is that it seems to only guarantee that it is close to the size. Can they guarantee that it is the exact size for 2010 Prius steering hub?
    I am new. I could not figure out how to edit my post. Please explain how.
    Someone said it is part of the airbag. UH Oh. Does that mean that even if I gently pry off the old one, that it will activate the airbag?
    Anyone out there done it?
  7. xliderider
    8,056
    3,223
    Honolulu, HI
    Here's a post with a step-by-step guide to disabling the airbag and removing the steering wheel. I'm sure you can figure out how to get the emblem off once you take everything apart. Contact the seller of the emblem I linked for precise measurements.
    https://priuschat.com/index.php?posts/2537032
    #7 xliderider, May 10, 2017
  8. Florida
    29
    Thanks xiliderider. My vanity has its limits. I would never take apart the steering wheel just for that emblem.
    Are you saying that it is not possible to pry off the steering hub emblem WITHOUT activating the airbag and THUS you have to take apart the steering wheel to do it properly?
    If so, then I will give up prying off the old emblem and gluing on a new one. I have heard that chrome nail polish at Walmart will do the trick.
    So it canNOT be simply gently pryed off with a thin screwdriver without activating something?
    Thanks
  9. tankyuong
    1,555
    661
    Central MO
    just paint it black
  10. Florida
    29
    Thanks Tankyuong. I will try my luck with Chrome nail polish first.
    Unless someone can answer my question: will pry out the steering hub emblem activate the bag if I do not turn the bag off?
  11. tankyuong
    1,555
    661
    Central MO
    only collision will trigger airbag
  12. Rebound
    3,972
    2,626
    Portland, OR
    I've removed the airbag before; it's pretty easy. But how does this help you get the emblem off?
  13. Florida
    29
    Thanks Tankyueng
    Rebound, thanks but I was actually trying to see if I could pry of the old emblem without disconnecting the battery, removing the steering wheel, and that prying it off will not activate the airbag.
    So now I have 2 choices.
    1) pry off and replace it with eBay emblem
    2) first try painting it with walmart chrome fingernail polish
    Thanks everybody
    This thread might be finished
