Replacing the 12V Auxillary Battery
Discussion in 'Generation 1 Prius Discussion' started by ryanca, May 12, 2007.
  1. ryanca
    ryanca New Member
    The 12V Auxillary Battery in my '02 Prius has come to the end of its life and needs to be replaced. I removed it from the car and had it tested at AutoZone, who confirmed that it was dead. Interestingly, AutoZone said they could not replace the battery, because they had no record of it in their systems.
    I called my local Toyota dealer and they said that the battery can be replaced with either Toyota part 28800-21050 or 28800-21190. However, both of these cost $138, which I feel is a little steep for a car battery. Is there something special about this battery, or is it OK to replace with a standard, 12V car battery, such as one that can be purchased at AutoZone?
    I just don't want to damage the hybrid system if there is something different electronically about these batteries. Anybody have any thoughts or experience on this? Thanks!
  2. tochatihu
    tochatihu Senior Member
    9,063
    3,530
    Kunming Yunnan China
    2001 Prius
    There be no electrical difference. Prius 'issue' is a vent tube to expel rare, unwanted gases from the common area, inhabited by you as well as the thing.
    Your $138 price from Toyota is lower than I have heard before. The standard suggestions have been elearnaid's battery and terminal kit (google it), or the same battery from MK with you making the terminals compatible.
    If you choose to believe that venting is not a critical requirement, a world of non-vented, about-30-amp-hour, 12 volt batteries opens up to you. Those could cost as little as $30.
    Fair warning, the issue of needing venting remains somewhat contentious! As I have said so much already, expect to hear some strong opinions on the subject.
    Back to basics, if you use a battery much smaller than 30 Ah, it will not manage the key-off parasitic load for very long. If OTOH you choose one larger, it will certainly weigh more and your task is that it should fit in the space available.
    Please never use any lead-acid battery in Prius without securing it well in place. Make its terminals free of corrosion, and keep them that way. That's about it.
  3. ryanca
    ryanca New Member
    <div class='quotetop'>QUOTE(tochatihu @ May 12 2007, 03:57 PM) [snapback]440701[/snapback]</div>
    tochatihu, thanks for the link to the Elernaid kit. One question, though, I disconnected the current battery already and didn't find any trace of "venting" installed. There was a large black vent hose running behind/above the battery, but it was not connected to the battery in any way. Also, it was not very securely sealed.
    Recently, I was in a collison and the side of the car near that battery was repaired. Do you think the mechanic never replaced the battery vent hose? I'm really glad I checked here first, thanks!
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    tochatihu, isn't the 2002 Prius the sedan? If so, the battery vent is on the side of the car.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    MPGnutcase likes this.
  6. c4
    c4 Active Member
    607
    51
    I replaced the stock Toyota battery with a Honda Civic battery- you need to order the version with the correct terminal orientation, but it's similar enough in size that you require minimal modifications to the bottom tray (it's got slightly greater width and about the same depth), and you have to fiddle a bit to get the top securing strap down (it's a tiny bit taller).. Then the battery terminals on the vehicle have to be replaced with North American sized parts.. The ground terminal is easy, just buy a pre-wired terminal and replace the OEM version; this is is IMO better than just replacing the terminal because the OEM ground wire is somewhat thin, and the replacements are typically much heavier gauge.. For the positive terminal, I got a "marine" terminal with the wingnut fastener on top- replace the wingnut and bolt with the original nut and bolt from the OEM positive terminal, and the new terminal basically bolts in place on the end of the original positive wire without any need to drill or hacksaw bits and pieces off..
    Best thing is that the new battery is a true AGM battery with no free electrolyte (all in the mats) vs the OEM battery which the Toyota literature claims is AGM, but in reality is a regular wet cell with sloshing electrolyte inside..
    I did *NOT* put any kind of vent tube in my car (a Classic Prius) because the new battery is AGM and has far lower gas emissions than the original liquid filled version and additionally, the hybrid battery cooling/vent system also happens to have a duct ending in the 12V battery well and this big duct by itself is much more effective in dissipating any hydrogen emissions than the tiny rubber hose which was probalby put on as a "just in case" measure..
  7. ryanca
    ryanca New Member
    Hey everyone, one more question. I'm looking into the Elernaid kit ( http://www.elearnaid.com/12vobaforpr2.html ) but it says that the kit may not work well for Priuses that had the Panasonic auxillary battery installed. Apparently the mounting tray is different(?) Turns out that my Prius did have the Panasonic battery rather than the original GX, so would I be better getting another Panasonic from the dealer? Apparently I can get it for about $138. Or would it be better to try and make the Elernaid one work?
    I would have never guessed that this 12V auxillary battery could be such a hassle! B)
  8. efusco
    19,891
    1,192
    Nixa, MO
    Choice is yours. If it were me I'd just avoid the hassle, shell out the $138 and get the OEM battery and be done with it. It'll probably last the life of the car.
  9. c4
    c4 Active Member
    607
    51
    <div class='quotetop'>QUOTE(efusco @ May 13 2007, 10:21 PM) [snapback]441376[/snapback]</div>
    Actually, the fact that he's looking for a replacement means that the OEM battery has *NOT* lasted the life of the car.. 5 years is pretty average for the life of a lead-acid car battery.. I don't know about you, but I fully expect my Prius to last a lot longer than that..
    I decided to go with a larger standard battery because #1, it's got a much higher capacity than the OEM and if I park it outside in an airport park-and-fly lot for 2 weeks in a Canadian winter, I'm absolutely *not* worried that I might come home to a dead car.. The fact that the battery was half the cost, even with the new terminals, and easily available from any auto-parts store was also a big plus.. Lastly, I've long beein of the opinion that the 12V charging regimen used by the Prius is suboptimal and results in the battery being only partially-charged much of the time, which leads to sulfation damage and premature battery death, and the AGM alternative battery is much more resistant to this than the old flooded plate style construction of the OEM battery..
  10. richard schumacher
    7,663
    1,040
    United States
    There is no direct drop-in replacement. Anything other than an OEM battery will need new cables to fit the posts. The Optima Yellowtop as sold by eLearnaid (Google it) comes with an adapter kit, detailed instructions, and fully charged.
    But what you really need is a new dealer. A dealer installed battery should cost in the neighborhood of $200, not $400. You are in luck in that you live within driving distance of Luscious Garage, hands-down the best Prius repair shop on Earth. Look 'em up.
  11. jreed
    jreed Member
    84
    71
    North Carolina
    I installed the Optima YellowTop from Elearnaid about two months ago on my '06 w/99K miles and it is still working well. The connector conversion kit wasn't too difficult to install and I saved the original cable in case I want to switch back to OEM for some reason in the future. I would recommend it.
  12. Patrick Wong
    18,200
    6,479
  13. davidj08
    davidj08 Junior Member
    79
    northern CA
    what dealer was it?
  14. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
  15. Zoe
    Zoe New Member
    2002 Prius
  16. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Never go to a stealer for your auxiliary battery. I replaced mine with a nice yellow top Optima batt from Advance Auto. AA may not have them in stock, but they can order the batt for you. It was a perfect fit with exhaust connectors and all.
  17. exbauer
    exbauer Active Member
    1,185
    100
    Washington
