Replacing the battery in an 05, Toyota or home maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeri, Jul 28, 2009.
  1. Jeri
    Jeri New Member
    I called the dealership and the price on the battery was acceptable, 138.75 but on top of that they want another 141.90 to install. This seems more than a big exorbitant. Can it be done by someone reasonably familiar with regular batteries or do I have to take it to a Toyota dealership?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Replacement is fairly easy. There are several posts showing how to do this, complete with photos.
    If you want to keep your settings, consider floating the 12V system with another battery at the jump points under the hood.
    Tom
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    $141 to install a battery! Another prime example of why my car will NEVER see the dealer for service unless it's paid for by warrantee.
    Assuming takes 1/2 hour, (I bet it would take less than 10 minutes) that is a shop rate of ~$280/hour, steep by anyones standards! On top of that they are making at least 50-100% markup on the battery!
    There is a reason those dealers are so *@#@*ng fancy!
    I bet you could find an independent shop to supply and install a Prius battery for under $150 total!
    Icarus
  5. Jeri
    Jeri New Member
    I have decided to let my local mechanic do the work and have downloaded the photos, instructions from the link. Next question when I buy the battery directly from Toyota, should that include everything I need? I noticed the mention of a kit but am wondering if that is only needed for a non Toyota purchase.
  6. boppo
    boppo Active Member
    799
    139
    Owego, NY
    qb3342,
    will a battery tender do the job or do you need a 12 volt battery.
    thanks,
  7. Jeri
    Jeri New Member
    I'll need the battery replaced.
  8. boppo
    boppo Active Member
    799
    139
    Owego, NY
    What I was asking was if I put a new battery in will the battery tender hooked up to the jump start plugs in the motor area work to keep all my settings when I disconnect the old battery.
    thanks,
  9. Patrick Wong
    18,200
    6,500
    Usually a battery charger will expect to see the battery produce a certain amount of voltage. If it senses that the battery is producing less than this amount (say if the battery is quite discharged, when you disconnect the battery, or if the battery polarity is reversed) then the charger will shut down for safety reasons. So you'll need to use a voltmeter with your battery tender to see what happens when you disconnect it from the battery.
    In general I would say that even if a battery charger will continue to produce voltage, this would not be a suitable backup source of 12VDC because the voltage produced by a charger typically is not filtered or regulated very well. Hence it may cause havoc with sensitive Prius circuits.
    I have a couple of lab power supplies that I could use for that purpose. If you don't have access to that type of device and feel the need to establish a backup power source then I would suggest buying a couple of 6V lantern batteries and wiring them in series, observing correct polarity when connecting them to the Prius.
  10. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Thanks Patrick,
    I got my optima battery today and they left the rebate form out and the battery was leaking in the box. I e-mailed them but haven't heard back.
    Thanks,
  11. priuslovers
    priuslovers Way Out Member
    65
    Hercules, California
    I just replaced my battery in my 05. I purchased it from e-learnaid in LA and it included the additional kit. It is the fairly new optima battery and was very easy to install (includes instructions). If you order before the end of july he will send you a $25 rebate, the cost of the battery was $160.
    Bernie - 818-364-9810
    good luck!
  12. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Bernie, told me to keep the damaged battery and he was going to send me a new one plus the rebate form.
  13. Jeri
    Jeri New Member
    Back to square 1 I received an email from Toyotapartscheap that my shipping costs would be increased to 35.00+!!! because of hazardous shipping. I am canceling. Does that indicate that batteries just can't be purchased online cheaper than the dealership?
  14. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    When I replaced mine, I just picked one up at the dealership for something close to $140. Took me 10 minutes to drive there pick it up, 30 minutes to replace, and 10 minutes to bring the old battery back to the dealer for recycling. Oh, and 5 minutes to reset the radio stations.
    For me it just wasn't worth the effort to search around for the best price online, pay shipping, search for a place to return an old battery, deal with making modifications or installing a kit, etc.
    Thanks,
    Shawn
  15. Patrick Wong
    18,200
    6,500
    Hi Shawn,
    Which dealer did you buy the battery from: Precision or Desert? I've just moved to the area, so I am interested in hearing your opinion about which dealer is better.
  16. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    When I've needed to (a few small parts, the battery, warranty work, and the inverter pump replacement), I've gone to Precision Toyota (it's also where I bought my Prius). Overall, I'm neither happy nor disappointed with their work -- it's pretty much like most dealers.
    For regular maintenance parts (oil filters, air filters, wiper blades), I order online.
    I have not dealt with Desert Toyota, so I can't say much about them.
    Thanks,
    Shawn
