Replacing the door
Discussion in 'Prius v Technical Discussion' started by RyanSB, Jun 28, 2022.
  1. RyanSB
    RyanSB New Member
    Washington
    Hey All
    I bought a complete (with intact wire harness) door to replace my drivers door. My question is how would I go about replacing the keyless entry and handle? Is the key detection part of the cars computer or is there something in the door I need to switch over? Im trying to make this easy as possible on myself.
    Thanks!
    52,378
    afaik, all the info is in the ecu. i would switch the whole door. if it doesn't work, you can switch the handles anytime
  3. Mendel Leisk
    41,892
    I would swap over the door handle. For sure the physical key would incompatible, for starters.
  4. ChapmanF
    18,534
    Just swap over the physical lock cylinder. That's easy. Besides that, a door's a door.
