Replacing the headlamp - some notes
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by 2sk21, May 14, 2014.
  1. 2sk21
    2sk21 Member
    138
    22
    Teaneck, NJ
    After two and a half years, the left side low beam headlight bulb burnt out in my Prius v. I looked through the manual and it appeared to be easy to do on my own so I got a replacement bulb from the dealer (and probably overpaid but just wanted to be safe).
    I have to say that access was really difficult. I had to remove and install the bulb socket purely by feel as I was really not able to see the socket. Once the socket was out, changing the bulb was very quick.
    While replacing the left side bulb is tricky but doable, the tight side lights are another story altogether since it appears that you need to remove the bolts securing the coolant tank. I'll leave that to the experts :)
  2. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    You should replace both headlight bulbs.
    The bulbs dim as they age, and the other bulb may be close to failing as well.
    Also, never touch the glass bulb with your fingers when handling the bulb. The oils left on the bulb will create a hotspot that will lead to premature bulb failure. If you do accidentally touch the bulb, clean it gently with a soft cloth with some rubbing alcohol on it.
  3. rjparker
    rjparker Tu Humilde Sirviente
    8,103
    4,806
    Texas Hill Country
    The passenger (right) side headlight bulb can be replaced by simply removing the air intake snorkel, using a socket, end, or hand wrench. Then reach in and rotate the bulb holder 1/4 ccw and remove. The wiring is long enough to get it out. Then disconnect the electrical plug with a screwdriver to fully remove the bulb and socket. If you do the more accessible driver's (left) side first you then know how it all fits. I did not have to remove the cooling reservoir. In fact I did both bulbs parked in front of the auto supply.
  4. gggGary
    gggGary gggGary
    79
    27
    Baraboo WI
    2023 Prius Prime
    XSE Premium
    Hi guys, new to me 12 v (lowercase v for the Prius v wagon) Two with 36K miles LH low beam out. Bulb number H11
    Has anyone tried an LED replacement for the H11?
    #4 gggGary, Jun 22, 2014
  5. cdrom
    cdrom Junior Member
    27
    Anyone have an idea on why, over last six months, four H11 low beam bulbs, on driver side have blown out. I've replaced each bulb myself and have made sure they are properly seated and have used electrical grease when changing them. Also, checked circuit breakers and they appear okay.
  6. gggGary
    gggGary gggGary
    79
    27
    Baraboo WI
    2023 Prius Prime
    XSE Premium
    Will just comment that the "super bright" halogen bulbs tend to have very short lifespans. My experience is that the regular halogens last longer.
    Look for any loose connections and or that you are getting the socket seated fully. Bulbs hate vibration and loose connections.
  7. schmuly
    schmuly Member
    209
    51
    BC
    Have you cleaned the glass on the bulbs with 99% rubbing alcohol so there is no hot spot?
    Also do a Google review of the bulbs that you installed, some are not very good and depending where whey were bought they could be counterfeit.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    As a matter of interest, what did you use the "electrical grease" on ?
  9. xliderider
    7,891
    3,125
    Honolulu, HI
    On/in the connectors that go on the bulbs, that's my guess.
  10. cdrom
    cdrom Junior Member
    27
    Yes, used the grease on the electrical connection and yes, made sure to avoid getting any on actual bulb. As to using the "brighter" halogen bulbs yes, I tried them at first but have gone back to OEM, which are now on both sides. I did not clean the bulbs with the rubbing alcohol but will try it; I've tried handling the bulbs carefully because of the potential hot spot problem from any oil but never know may have touch them inadvertently. The idea about the bulb going out do to vibrations may be next thing to check. Thanks for the replies.
    schmuly likes this.
