REPLACING THE HEADLIGHT LAMP ON A 2015 PRIUS C
Discussion in 'Prius c Technical Discussion' started by CARSFAN4, Apr 7, 2023.
  1. CARSFAN4
    CARSFAN4 Junior Member
    23
    Los Angeles
    2015 Prius c
    My front right headlight lens is broken and although I sealed with tape the rain water got inside the headlight casing so it doesn't work anymore. I watched a YouTube video but I cannot open ( rotate ) the bulb from the engine compartment.
    I called Autozone and they told me that it shows non serviceable in their computer so probably they don't carry only the bulb.
    Can somebody help me out to lmk if it is true that the bulb cannot be replaced by itself and I need to buy all the headlamp? Thanks !!!
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Pretty sure the 2015 has lifetime LEDs. No bulb to replace. Check your owners manual for real confirmation.
    Probably cheapest to get a used one, try car-part.com
