Replacing the main coolant water pump on 04 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tmorrowus, Sep 16, 2009.
  1. tmorrowus
    tmorrowus Member
    514
    The last time I brought my '04 Prius in for an 80k oil change, the dealer noticed that my coolant level was very low and showed me that there was dried out coolant under the bearing on the water pump where the engine belt drives it. So it seems to have a slow leak, and I need to get the water pump replaced when I can.
    The water pump itself costs $101 from the dealer, but the dealer wanted $450 for part and installation which seems excessive.
    I'm curious what other people paid to have their main water pump replaced, and if this is something that I might be better off taking to an independent shop now that my car is out of warranty?
  2. tmorrowus
    tmorrowus Member
    514
    BTW, I suppose I should have the belt replaced as long as they're in there, right?
  3. Patrick Wong
    18,200
    6,471
    You should have the serpentine belt replaced since it is pretty inexpensive (around $20) and there's no additional labor involved.
    One reason that the labor content is high is because it is not easy to replace the engine coolant given the presence of the CHRS canister which is hard to purge of air. An independent shop is an OK alternative if the tech is a Toyota specialist trained on Prius (or at least has access to the Toyota diagnostic tools and repair docs.) I suggest that you start by looking for independents that specialize in Toyotas. If the shop doesn't specialize, it is not likely it will have access to the diagnostic tools.
  4. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    I'm sure a higher-end aftermarket scan tool such as an OTC Genisys, Snap-On Solus Pro, etc with bi-directional support will have nearly the same capabilities as a factory scan tool.
    I've been told that using an Matco AirLift is the easiest way to fill the system and to remove air from the CHRS canister in one step.
  5. nthach
    nthach New Member
    174
    Prius: 30k Service
    They're showing a AirLift at work here.
  6. acacia987
    acacia987 Junior Member
    44
    MD
    wow thats a lot of 30k mile service!
    Also, i wonder if the AWS fluid for the transaxle is that moisture sensitive that filling it from the top with a funnel would be detrimental ( a way i seen done on this forum).
  7. Worknclassbug
    Worknclassbug New Member
    Huntington WV
    I just had to have my water pump replaced on my '08 with 30K on it. Seemed like a premature failure. Was covered under warranty but the dealership had it most of the day and managed to leave bolts loose and one of my radiator cover bolts is missing. I won't be returning to that dealership...
  8. Patrick Wong
    18,200
    6,471
    I question the assertion that WS ATF is particularly moisture sensitive as the bottle labeling is silent on that question.
    In any event, the WS ATF gets pretty hot in normal use so any moisture should vaporize. As the transaxle gets hot, air pressure builds up within the case. A one-way vent lets that pressure out (along with any water vapor from the fluid.)
    Then when the transaxle cools down, a partial vacuum forms. This is why, when you open the transaxle fill plug with the transaxle cold, you will hear a hiss. That sound is air entering the transaxle. If you open the fill plug when the transaxle is hot, you will not hear that hiss.
    There are six black plastic fasteners that hold the black plastic radiator cover on (the fasteners look like Philips screws but they are not screws). If you want to buy a replacement fastener it will probably cost around $2 from the dealer's parts counter. Maybe the missing fastener broke when it was removed (they are pretty fragile.)
    What bolts are "loose"? That doesn't sound good... However, if you are talking about the black plastic fasteners for the radiator cover, they just snap in place. It's OK that they can be rotated by hand, while in place.
  9. Worknclassbug
    Huntington WV
    The mechanic left a water pump bolt lose. By the time I got home it had backed out about a quarter inch. I tightened the bolt and went around the pump to make sure all of the rest were tight as well. You are right about the plastic fasteners. They are fragile but the mechanic didn't lock them down. When I got home most of them had come unpopped and I'd say one vibrated out. After I clicked the others in place they have stayed. I'm going out now to check my fluid levels and make sure I have no leaks. I have had very bad luck with dealers in my area. Seems like they get their certifications out of a cracker jack box. I'm a better mechanic than most of them and that doesn't say much. They didn't take the time to make sure the coolant level was right either. After going home and letting the car cool the radiator drew all of the coolant from the clear container and I couldn't see any in the radiator neck so I had no idea how much was inside the radiator. After dropping $22 at my local dealer for a gallon of coolant I filled the radiator and the clear bottle. I'm not happy with either of the dealers in my area. The one that worked on the Prius also sells Benzs and some other high dollar cars. I figured they would have excellent mechanics.
  10. Patrick Wong
    18,200
    6,471
    Good for you that you noticed and took action. Since you are able to tighten the water pump bolt, maybe next time you should just do the job yourself, then you'll know that it was done correctly... Incidents like the one you mentioned prompted me to learn enough about the Prius so that I can feel comfortable repairing most issues DIY.
  11. tochatihu
    tochatihu Senior Member
    9,044
    3,528
    Kunming Yunnan China
    2001 Prius
    Workinclassbug, toyotatechwv posts on Priuschat. If near you perhaps that would be a good choice for future service?
  12. jk450
    jk450 New Member
    That is false. Notwithstanding the CHSS system, the engine coolant can be replaced in ten minutes by someone with experience and proper tooling. The labor cost reflects the labor required to remove and replace the mechanical water pump.
