Replacing tie rods & rack & pinion.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Davidude, Jul 6, 2020.
  1. Davidude
    Davidude Junior Member
    94
    Georgia
    Mechanic told me I'd need to replace my rack & pinion soon. After checking with a friend of mine, he said I can wait a few thousand miles before replacing it. My steering wheel has a little play when going straight, the alignment is perfect though. No bad tire wear or swerving on the road.
    Rockauto has racks & pinions (including inner tie rods) for $200-$400. How difficult is this to install? My friend is very familiar with working on his for his 4runner, which is heavily modded.
    I also see outer tie rods for $13 apiece. Those are much easier to replace I hear, but I'll need an alignment after any of this work. However I need them more urgently, my wheel assembly shakes left to right when jacked up. Hate to get two alignments within a short period of time but may be the best option.
    Will I need to go to a specialist for the rack & pinions? Does the computer interact with it, or is it just hardware?
    I've been working a lot on my motorcycle so I feel more confident messing with the rack, but I'd hate to brick the Prius.
    49,474
    how many miles on her?
    this is the 2004, not a prime?
  3. Davidude
    94
    Georgia
    Meant to include that. It has 189k miles, and it's been under a lot stress. Not too worried about replacing the suspension parts, it's probably overdue by now. But the rack & pinion seems like not an uncommon replacement, but I wonder if it's really necessary.
    I've decided to visit a dealership to bleed my brakes ($90 roughly), and I'll have them inspect the rest of the car as well. A second, more qualified opinion may tell me this is all BS. I realized that the mechanic I visited was blaming spongy brakes on the rack & pinion. It makes sense for them to not perform at 100%, but I'm very confident there's air in the system right now. It feels just like my motorcycle before I bled those brakes.
    49,474
    prius steering is electric, so idk if 4runner is a good example. rack and pinion is pretty unusual, and i don't see how it can be related to brakes.
    prius brakes are also electric, and bleeding is a bit tricky. there can also be brake actuator problems.
    Davidude likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Your posting it in the wrong forum. Use the G2 forum you will get more eyes on it this is the new prime forum.
  6. Davidude
    94
    Georgia
    Thanks, no idea how I posted it here.
    edthefox5 and Mendel Leisk like this.
