Replacing water pump - what about idler pulley?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ozymandias, May 6, 2012.
  1. ozymandias
    ozymandias Junior Member
    83
    Virginia
    The water pump on my 04 with 132k miles is rattling / wobbling (but surprisingly, not leaking). So I am going to replace the water pump, serpentine belt, and thermostat. The idler pulley seemed fine so I am wondering if I should replace it. What is the failure mode on the idler pulley and how will I know it is going bad without having to check it? Or should I just go ahead and replace it?
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    You are in there anyway so why not replace it to be on the safe side. For me, I'd hate to do that work and go back in there 6 months later to replace a pulley.
  3. ozymandias
    83
    Virginia
    Replacing the pulley would take less than 5 minutes.
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The absolute failure mode would be bearing seizure which would result in it throwing or destroying the belt. The way that you'd know it is going bad would be noise (high pitched bearing squealing at first, harsher, more grindy noise later). Given the isolation of the engine compartment from the cabin, you'd probably notice it as reflected noise off of buildings or other vehicles. The noise can continue for a long time before the pulley seizes though. Listen under the hood every 6 months or so and you should be good.
    - Chris
  5. ozymandias
    83
    Virginia
    Thanks...that's what I needed to know...I'll save the $45 for now and replace it when I hear it start to go bad. The car is parked in a garage so I should hear it pretty easily....that is how I found out the water pump was on it's way out.
  6. ozymandias
    83
    Virginia
    Hmm, I just realized that Rock Auto sells Bosch water pumps for half the cost of OEM...I assume they are just as good?
  7. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Bosch is as good a name as any, though I don't usually think of them for water pumps.
  8. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    1 - Replacing the idler pulley is really REALLY easy on the Prius. About 5 minutes - you don't have to mess with the water pump or the belt.
    2 - The thing that fails on the pulley is the bearing. That bearing is a 6301 size bearing - really pretty stout for what it does. If you're handy, you can simply replace the bearing - for example: 6301-2RS Bearing 12x37x12 Sealed Ball Bearings
    3 - If you simply replace the bearing, it will cost you ~$10 for a high quality bearing.
  9. ozymandias
    83
    Virginia
    Hmm, that's interesting. Thanks for the info! Unfortunately I don't have a press to replace the bearing. Anyway, it sounds like I might never have to replace the idler pulley anyway. So I'll cross that bridge when I get to it! :)
    After shipping costs and all the other parts (thermostat, gasket, belt), RockAuto wasn't a whole lot cheaper so I just went with the OEM water pump.
  10. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    OZ- I replaced the water pump in our '06 last year. Not a difficult job but it does require you to get into some tight spots. You should take off the pulley to gain easier access to the water pump anyway, so i say change it while you have it off. I would also recommend changing the thermostat while you're there for <$15 and the serpentine belt(if you haven't changed it yet). Oddly enough the pulley is the most expensive replacement part in this group. As for the Bosch water pump it is probably just as good as the original. I think you be amazed as I was about how small the water pump actually is. I took pictures of the process when I did the water pump replacement with the intention of putting a sticky on the site...but life has gotten in the way. I will make an effort to get it done in the next day or so.
