Replacing WS transmission fluid with ARCO Graphite Oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kohnen, Apr 1, 2010.
  1. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    Hi All!
    I have an '07 Prius. Reading the posts, folks recommend changing the transaxle fluid at about 60000 miles.
    I have a bunch of old ARCO Graphite motor oil (10W-40). Our transmisions have no clutches, only gears and a drive chain.
    It seems to me that, in this case, the graphite in the oil would be ideal for minimizing wear in the Prius transmission.
    What do you guys think? Should I replace my transmission fluid with 4 quarts of ARCO Graphite oil? Good idea, or bad?
    Thanks!
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Very bad idea...
  3. Patrick Wong
    18,200
    6,474
    Extremely bad idea. Excluding considerations of chemical content, Toyota ATF WS has very low viscosity, one or two steps up from water. 10W-40 is very viscous, so you would expect to see much more drivetrain friction.
  4. jdenenberg
    jdenenberg EE Professor
    3,852
    1,846
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The motor-generator windings are exposed to the ATF. Graphite conducts electricity. You have a very bad idea that could cost you $$$ to repair.
    JeffD
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    April Fools? :madgrin:
    I actually tried Arco Graphite oil in the 80's in my Ford Courier. It was difficult to tell the condition of the oil from looking at the dipstick because the stuff was pitch black when even when new. I remember that it stained the paint permanently when I accidentally spilled a drop on the hood.
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Right on! :D
  7. kohnen
    317
    57
    Fullerton CA
    DING DING DING DING DING!!!!!
    I was wondering how long it would take! :rolleyes:
  8. dogfriend
    7,512
    1,185
    Carmichael, CA
    I wonder if Arco Graphite oil has any collectors value? It was certainly unique.
  9. kohnen
    317
    57
    Fullerton CA
    Folks are trying to sell it on the net for ~$10 per can as a collector's item (that's how I got the info).
    I bought and used ARCO Graphite oil back in the day [sadly, I can't quite remember when that day was]. Worked fine, no problems with it. It was oil - meh. But, yeah, God help you if you dripped it on ANYTHING that you didn't want to be stained! The former home of my parents STILL has the stain of a messy graphite oil change on the garage floor.
    (I've been waiting for April Fools for ~6 months after I came up with the idea for the original post).
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    That was my experience as well.
  11. bisco
    49,479
    ouch! i am so gullible!:rolleyes: good one!
