Report - 04 - Broken Glove Box Springs - Extended Warrantee
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tempus, Nov 7, 2007.
  1. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Well, as usual, I finally got another of the 'teething pain' failures all early adopters are heir to.
    Both springs in the upper glove box broke loose. I took out the glove box to prevent any damage to the dash, then pulled out the Extended Warrantee.
    Now, this is only applicable to the Platinum Version. The regular covers less.
    There, under "Other" was "Glove Box Assembly".
    So far so good.
    Off to the dealership, first stop the parts department to check it out. A parts lookup showed a $115 part named "Glove Box Door".
    Hmm, well, a Door is clearly not an Assembly. But, the part is the whole shebang with door, glove box, hinges, springs, gears, latches etc. Sure looks like an "Assembly" to me.
    Off to the Service Writer. I tell him my Glove Box Assembly is busted.
    Check Warrantee - Glove Box Assembly - ok, looks like you're covered.
    I tell him - "When you call the adjuster, be sure you tell him it's an Assembly. The database just calls it a "Door" but look at all these moving parts, someone sure assembled it. He chuckles.
    Call to the Adjuster -
    Mutter Mutter -
    Service Writer says, Yes, I know the part database calls it a Door but look at the diagram, it's an Assembly.
    Mutter Mutter -
    Ok, you're covered. 0 deductible.
    Oh, and apparently for Platinum Warrantee Repairs, Toyota doesn't want the broken part back. Anyone need a broken "Glove Box Assembly"?
    I do suspect they've gotten enough of them back already that the have a pretty good idea what went wrong :)
    So, the lesson is, it's all in the language. The Service Writer agreed that if we hadn't been prepared to argue that a "Door" would not have been covered.
  2. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    Good to hear that it's covered when you call it what it is.
  3. richard schumacher
    7,663
    1,038
    United States
    Tempus, how did you remove it? Mine died the same way about a week after the warranty expired. I see a release clip on the left end but I don't see how to free the right end.
  4. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    very easy, richard- 2 screws in the back iirc. DH did ours shortly before our basic warranty ended.
  5. richard schumacher
    7,663
    1,038
    United States
    Are they behind the two round plugs in the back? If so how are the plugs removed?
  6. galaxee
    9,810
    465
    MD
    yep- that's it. DH has a small pick he uses to pull little plugs like that. just get something behind there carefully and pry.
  7. richard schumacher
    7,663
    1,038
    United States
    Thanks. I gouged mine pretty well removing them, but then I did manage to fix the broken spring so I'll call it a bargain.
  8. DaveG
    DaveG Member
    806
    Vancouver, BC
    Had the exact same problem on my '04. Faulty design on the spring retaining mechanism behind the upper glovebox caused the springs to break out of the plastic retaining grooves and push the dash covering up (in addition to no longer opening the glovebox properly). Rather than just paying Toyota for a replacement, I decided to fix it myself.
    Removing the upper glovebox lid assembly wasn't too bad. Just empty it out and remove the trays. You'll see two small plastic covers. To remove them, slide a thin knife blade in on the left or right side. They'll pop out quite easily (there are small notches on the left/right sides of the plugs that catch in indents as shown in the picture).
    Once you remove both plugs, remove the phillips-head screws and pull the glovebox straight towards you. There are two nylon clips that hold it from behind.
    Take care not to pull too far as there's a yellow electrical wiring harness behind it that's attached to the glovebox assembly for some unknown reason. Squeezing the white clip together at the bottom allows easy removal.
    Once the box is removed, it's easy to see the source of the problem:
    In both pictures, you can see where the heavy metal spring end has snapped-off the edge of the plastic, allowing the spring to escape from the groove so the opening mechanism no longer functions properly (and it pushes the dash up as well and warps it).
    After a little thinking (and a bit of experimenting), I found a simple solution. I mixed up some 2-part epoxy glue, and snapped-off about 3/8" of the thin end of a wooden clothespeg to create a wooden shim. After liberally applying the mixed epoxy, I pushed the shim into the slot with a flat head screwdriver so it was nice and snug. I did the same thing to the spring on both ends of the glovebox.
    After letting it dry overnight, I reassembled the dash. Everything works properly now and the dash is in good shape.
    Dave
  9. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    And I busted the tip on one of my wife's good kitchen knives doing the same thing. :( But I did get the glove-box out. :)
  10. SureValla
    SureValla Member
    590
    Shelton, CT
