RePost: Highway Wind Stability Problem Summary
Discussion in 'Knowledge Base Articles Discussion' started by 200Volts, Oct 14, 2005.
  1. 200Volts
    200Volts Member
    429
    43
    Northern CA
    Summary of my experiences and opinions:
    The stock Goodyear Integrity tires with 40k miles (10 months) on my 2004 Prius were replaced with Bridgestone RE950 tires of the same size-diameter. The Bridgestones are a huge improvement in handling-stability at freeway speed, have fantastic dry and wet grip and are better on irregular surfaces. After the first 4,500 miles they have an average amount of noise (the Integrities are quiet when new), provide a firmer ride and get about 3-4 mpg less (now averaging about 49mpg combined driving). They are an excellent value ($70 each sale price w/mount-balance). I would definitely buy these tires again.
    RE950 Performance Summary (see attached file)
    Tested over 4,500 miles combined driving. MPG done on 160 mile commute (30 mi 2 lane country-55 mph, 30 mi freeway with 1,000 foot climb-decent 75mph, 20 mi stop-go, city driving 35 mph).
    Prius Background
    Many 2004-2005Toyota Prius owners have been struggling with stability issues at highway speeds on the 2004-2005 models. These issues include poor cross wind stability, poor tracking and twitchy handling on irregular surfaces. The magnitude of this problem can be seen on the popular PriusChat.com website with over 10,000 views of the topic “Poor Steering and Handling on the Highwayâ€. Considering that about 24,000 Prius models were sold in 2004 and many magazine reviews have made note of this issue, highway handling is an area that needs improvement on the Prius.
    Most people buy a Prius because they want outstanding gas mileage. This has caused many Prius owners to inflate their tires from the stock 34front/32rear psi factory suggestion to as high as 42/40 psi. Increasing tire pressure does increase mileage by about 1 to 2 mpg. Increased pressure also helps reduce the rolling and yawing tendency of the Integrity tires (at the price of a very firm to stiff ride quality at 42/40 psi interior parts start to vibrate over irregular surfaces). However, even at 42/40 I think the Goodyears have terrible side wall flex which leads to very twitching handling at highway speeds with the relatively narrow and tall Prius. The stock Prius shocks and springs are rather stiff (possibly to compensate for the weak tires ?). The front sway bar-bushings and rear torsion bar perform their jobs adequately. Adding further turmoil to the Prius’s handling woes is an electrically boosted power steering system with excessive boost at all speeds and a moderate amount of dead center play. This tends to cause the driver to over correct at highway speeds. The Prius also has a very sealed up under body (presumably to help minimize aerodynamic drag). Testing with different air dam locations on the front of the car has shown some improvements in highway speed handling.
    All this raises the question “Is it the Goodyear Integrity tires or something else in the Prius (or a combination)?†To answer this I rented a Ford Focus and Toyota Corolla S for two days each of highway driving. The Focus has nearly identical dimensions to the Prius and drives much more stable even with Goodyear Integrity tires (60 series vs. the 65 series on the Prius). The Focus has an excellent ergonomic steering wheel with just enough boost in the power steering to feel “rightâ€. The Corolla has the same size wheels and tires as the Prius, but handles like an average small 4 door car. The steering setup in the Corolla is much better then in the Prius. The Corolla “S†package has front chin spoilers, side skirts and a small rear deck spoiler to help aerodynamics.
    Based on the contrasting test drives I would conclude that the problem is very poor tires combined with poor front end aerodynamics and steering. On my test car I ran the stock and modified front air dam positions with the old and new tires. Moving the air dams forward helped with both manufacturer’s tires, but the Goodyears still felt very unstable at highway speeds. During crosswinds and lane changes the Goodyears felt like the back end was ½ a second behind the reaction of the front. Some Prius drivers describe this as the back end wanting to swap with the front. I feel like the front tires roll first, then turn while the rear tires are still flexing until they roll over enough to start to follow the front. Combined with the poor power steering setup this can cause a quite unnerving ride when passing large trucks or in a cross wind.
    With the Goodyear tires you can push on the side of the rear bumper of a parked Prius and see the car yaw left to right. The wheel to fender distance stays about the same, while the stock tires “twistâ€. Pushing on the top of the “B†pillar produces a similar effect but in a “roll†mode. With the new Bridgestone RE950 tires neither of these two effects can be seen. This a crude test, but does indicate a much more stable side wall.
    Data
    Alignment- done twice a Tracy Toyota, Tracy CA. Test car drives straight and has no accidents.
    FrontLeft FrontRight FRONT RearLeft RearRight
    Camber 0.8 0.8 0.0 -1.0 -1.0
    Caster 3.4 3.1 0.2 0.18 0.23
    Toe -0.02 -0.01 -0.02 0.18 0.23
    Incl angle 9.7 8.3 ….. ….. ….
    Tread Depth (mils) Integrity after 40,080 rotated every 10k
    FrontLeft FrontRight RearLeft RearRight
    Inside 14 15 17 13
    Middle 12 15 16 13
    Outside 10 11 12 12
    Tread Depth RE950 after 4,500 (no rotations)
    Inside 26 27 28 29
    MiddleIn 32 33 32 32
    Outside 26 27 27 27
    The RE950 depths indicate under inflation (tread depth in middle of tire is thicker).
    The front driver tire is subject to extra wear. This has been reported on Prius models since 2003.
  2. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    Great writeup, thanks. I had those same tires on a 2004 Prius, but in 195/60-HR15 size. I agree with everything you wrote about them, a great all-weather high performance tire that made Prius into more of a sports sedan than econobox. They developed so much grip that the car needed more roll control. I sold the car with 4K miles. The new owner called after he accumulated 10K and said the tires became noisy beginning at 5K and were now so bad that he was replacing them.
    My next 2006 Prius will get either those or probably the Yokohama Advan db (?) series all-weather high performance tire. I think the added safety margin and fun factor is worth the fuel economy hit.
  3. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    I had 31 pounds in the front tires for whatever reason it was low. Raised it to the 35 and it is 100% stable at highways speeds with a cross wind.
  4. camry25
    camry25 Junior Member
    46
    l.a.
    Have newest Prius fixed this problem?
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The Gen III (2010 and newer) has a new design for the rear suspension and fewer problems with stability.
  6. brugins
    brugins New Member
    I've had these same problems with the 2007 Prius I bought last year. The car gets really tricky to control in gusty high cross wind situations. I recently increased the tire pressure to 36 psi from factory-recommended 33-35 psi. That seemed to help. But the stability problem, along with the loose steering, makes me very unhappy with the car's handling. (I wish I still had my Corolla FX16 GT-S!) Does anyone have any recommendations for tires or anything else that would improve my driving experience?
  7. brugins
    brugins New Member
    Well, I just replaced the stock Goodyear Integrity tires with Michelin Defenders. I inflated the new tires to 37 front and 35 rear. And guess what? The handling is just as bad as it was before. Conclusion: The Prius suffers from many serious design flaws and will probably always handle poorly. It wanders all over the rutted and grooved highways we have in Texas. In my opinion, the very poor handling and the very obstructed view to the right rear and through the peculiarly segmented rear window make this car unsafe under any conditions at any speed. I have never experienced anything like this in 58 years of driving many cars in all kinds of conditions. Moreover, my Prius has fallen far short of the gas mileage tauted by other drivers and testers: it has averaged only 40 mpg in the year I have owned it (17,364 mi./433.6 gal.). The savings in gas money just isn't worth it. After several close calls, I'm afraid to let my wife and son try to learn how to drive the thing. I plan to trade it in on a decent handling car in the near future.
  8. bisco
    49,488
    how fast are you going, 100?:rolleyes:
