Required Maintenance
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fisher, Dec 23, 2014.
  1. Fisher
    Fisher New Member
    Kelso, Washington
    Hi: I just took our Prius into the dealer for the 30,000 checkup. They changed the oil and filter and went through 40 plus checks on a checklist. Most everything passed except three areas failed! They were: Electronic fuel injection flush 129.95, evaporator sterilization and flush 170.00, Air condition service 160.00 Estimate total with shop fees and tax = 562.72. Wow! I did not have this done as I'm not sure if this is a nice to do or a have to do. I could not find any of this in the 30,000 maintenance schedule. What are peoples thoughts on this?
  2. JC91006
    16,672
    8,518
    never heard of anyone doing those services at 30k. I suggest you find a more honest dealer.
    51,140
    sounds more like a wallet flush.:p dealer fail.
    sdtundra, xpcman, macman408 and 3 others like this.
  4. irrational
    irrational Member
    102
    38
    Tulsa, OK
    My thoughts; This dealer is a crook. Either find a better dealer, or do it yourself.
    IIRC at 30K you;
    • Change oil & filter
    • Rotate tires
    • Replace air filter
    Everything else is visual inspections. This should be $200 tops, and that's pretty generous given that a professional with proper tools (e.g. hydraulic lift, air tools, etc) could do all of this in 30 minutes.
  5. caedward
    caedward Junior Member
    Fort Worth, Texas
    Wow, sounds like your dealer needed to make a boat payment. Run very quickly to another dealer.
  6. Fisher
    Fisher New Member
    Kelso, Washington
    Thanks, I thought this seemed unnecessary.
  7. bisco
    51,140
    welcome to priuschat! your home away from home.:)
  8. Fisher
    Fisher New Member
    Kelso, Washington
    I did see a large yacht parked in the lot! I will now run quickly, away!
    definitely. Glad I had enough sense to wait. I saw a number of elderly folks at this dealership and I fear they might fall prey to this hype. Strong words like status Fail, makes you this this is serious.
    #8 Fisher, Dec 23, 2014
    retired4999 and irrational like this.
  9. Mendel Leisk
    40,574
    Did they actually use the expression "failed"? It seems misleading, likely intentionally. Their forte looks to be promoting unnecessary extra services. And I wouldn't doubt when serious diagnostics are needed, they fall short.
    See if you can find a more common sense dealership. One simple test: phone several parts departments, ask for info on some item, a little out of the norm, say a block heater. See what they all come back with. The differences can be surprising.
  10. Fisher
    Fisher New Member
    Kelso, Washington
    Thanks for the welcome. A friend told me to check out this website and I'm so glad I did. Thank you.
    They did use the term Fail. It was on the vehicle report that was handed to me.
    #10 Fisher, Dec 23, 2014
    irrational likes this.
  11. JC91006
    16,672
    8,518
    That's pretty deceiving to use the word fail for maintenance that may not be necessary. It's not even a repair. If you complain to the service manager, he might give you a free oil change so they can try to empty your wallet again
  12. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Are you having any issues do you feel with any of the listed "failures"?
    If you feel you are, on the cheap try this first:
    If ac is smelling moldy, spray a good amount if Lysol into where your cabin filter is.
    If car feels like it's fueling is off, ie. clogged injectors, try a bottle of fuel injector cleaner for a few bucks avail at any auto parts store.
    Is your ac blowing cold?
    If everything seems fine to you, then walk away knowing you just saved a few hundred...and didn't get screwed from the stealership.
  13. bisco
    51,140
    it was very astute of you to walk away and educate yourself. your right, they may be taking advantage of seniors, and that could be illegal in some states.
  14. frodoz737
    frodoz737 Top Wrench
    4,530
    2,437
    33
    Please scan your "failed" paper work for us to see.
  15. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    Hope they removed the summer air , and put in winter air in the tires , many dealers will leave in the same air year round
    Detay, Yakoma, maurices and 3 others like this.
  16. orenji
    orenji Senior Member
    5,886
    3,487
    Report them to Toyota Corporate, I am sure they would like to know of this dealers sales tactics.
    #16 orenji, Dec 24, 2014
    maurices likes this.
  17. Dave14Prius
    Dave14Prius Member
    72
    26
    NE Missouri
    Sounds like a rip off to me also.Scan in the service write up ,please.
  18. Blizzard_Persona
    1,787
    946
    Pa.
    2023 Prius Prime
    XSE
    Also, right around 30k miles the crappy oem blinker fluid has been known to get gummy and cause issues.... I truly am surprised that this did not fail as well...??
  19. Yakoma
    Yakoma Active Member
    470
    125
    sss
    F&*(ing stealership. They were trying to get their kids better Xmas presents, I guess.
  20. Fisher
    Fisher New Member
    Kelso, Washington
    Thanks for the suggestions. There is nothing wrong , smelly etc with the air conditioning or fueling issues. The only funny smell was the service report.
    Here is the service report below called 30K. Sorry it took me a while holidays and all.
    #20 Fisher, Dec 26, 2014
    SageBrush likes this.
