Required some assistance to find fog lights & drl space
Discussion in 'Gen 3 Prius Accessories and Modifications' started by shahid, Feb 5, 2016.
  1. shahid
    shahid New Member
    Islamabad
    20160131_165326-1-1.jpg Hi
    I have recently purchased Prius 2012 JDM. It s L edition (Base edition). I want to install fog lights and drl. But couldn't find any space.
    Kindly require guidance.
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    What's under the turn signals? On the USDM Prius there are LED DRLs.
    You will need to get a lower grill with openings for the foglights, or cut openings out of your lower grill. The mounting points for Toyota oem type foglights are behind each end of the lower grill.
  3. shahid
    shahid New Member
    Islamabad
    Thanks for reply
    There is nothing under the turn signals.
  4. xliderider
    7,848
    3,102
    Honolulu, HI
    Then you can probably get some USDM turn signal/DRLs and install/wire them into your JDM prius.
    You will have to directly wire the DRLs to make them functional.
  5. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
  6. xliderider
    7,848
    3,102
    Honolulu, HI
  7. xliderider
    7,848
    3,102
    Honolulu, HI
    @shahid, I like how the JDM base Prius has turn signal indicators on the side mirrors. (y)
    shahid likes this.
