Rescue Workers say Hybrid Cars a Danger
Discussion in 'Gen 2 Prius Main Forum' started by Tempus, May 4, 2004.
  1. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    http://news.yahoo.com/news?tmpl=story&u=/a...d_car_rescues_1
    Rescue Workers Say Hybrid Cars a Danger
    Tue May 4, 3:04 AM ET Add Business - AP to My Yahoo!
    By PATRICK WALTERS, Associated Press Writer
    PHILADELPHIA - The growing popularity of hybrid vehicles is a step toward cleaner air and less dependance on gasoline. But for rescuers at accident scenes, they represent a potential new danger: a network of high-voltage circuitry that may require some precise cutting to save a trapped victim.
    "You don't want to go crushing anything with hydraulic tools," said Samuel Caroluzzi, an assistant chief with the Norristown Fire Department outside Philadelphia. "It's enough to kill you from what they're telling us in training."
    Hybrids draw power from two sources, typically a gas or diesel engine combined with an electric motor. The battery powering the electric motor carries as much as 500 volts, more than 40 times the strength of a standard battery.
    That worries those who must cut into cars to rescue people inside.
    "If you can't shut it down, you don't know where the high voltage is," said David Dalrymple, an emergency medical technician in New Brunswick, N.J.
    Manufacturers have put in place a laundry list of safety checks that the car's computer must go through for the electrical system to run. They've published guides showing where the electric components are on their models; on the Toyota Prius and other hybrids, the high-power cables are colored bright orange to catch the eye of a rescue worker or a mechanic.
    But there are concerns over what happens if something goes wrong and the battery, ignition and other points are inaccessible.
    "It's the 'what-if' that worries me," said David Castiaux, an instructor for Mid-Del Technology Center in Del City, Okla., who teaches rescue workers about hybrids.
    Chris Peterson, a service training instructor for Toyota, said the Prius' electric system should shut down if anything goes wrong. "There should not be high voltage in those cables, but I'm not going to stand up and say there isn't," he said.
    First responders are taught to disconnect the battery and turn off the key immediately before cutting into a car, but that's not always possible.
    "Years ago you could just cut with your extrication tools through a post, but now you have to look before you cut," said Ken Nelsen, chief of the Iselin Fire Department District 11 in Woodbridge Township, N.J. "It's just another thing you need to worry about."
    When air bags started becoming more common in the 1980s, rescue workers became aware of their potential to seriously injure or kill when inflated. Those concerns have been heightened now that the safety devices are being installed in side panels, seats and other areas.
    Concerns about hybrids are increasing in large part because of their growing popularity. Sales have risen at an average annual rate of 88.6 percent since 2000 and recent figures show the number of Americans driving them jumped more than 25 percent from 2002 to 2003.
    The Honda Insight and the Toyota Prius are common now and more are on the way: hybrid versions of the Ford Escape, Honda Accord and Lexus SUV this year, and a Toyota Highlander in 2005.
    The Alachua County Fire Rescue in Gainesville, Fla., even has two hybrids of its own. Although its crews haven't had to deal with a hybrid crash, they've been getting versed on what to do when it happens, said Cliff Chapman, assistant chief.
    They know not to cut into a hybrid's doors — that's where many of the cables are — and to peel off the roof instead. They also now operate under the assumption that a car is energized, wearing rubber gloves and boots.
    Manufacturers say they will continue to keep rescue personnel up to date on their hybrids. But they also contend that hybrids can be seen as safer than regular cars.
    "Everybody's concerned about the electrical side, but could you imagine if we tried to bring gasoline out today as a motor fuel?" Peterson said.
  2. ErikS
    ErikS New Member
    Stockholm, Sweden
    Yeah, there was a big discussion about this in Sweden a couple of moths ago. The firefighters went as far as telling people that they would not rescue someone in an electric car or hybrid... I think (hope :) ) the manufactures and the rescue personnel worked it out.
    I wonder why the japanese guy who made this webpage referred to the left back seat as the suicide seat... Could it have something to do with it being close to the battery and high voltage cable running under it??
  3. KMO
    KMO Senior Member
    1,539
    421
    Finland
    2023 Prius Prime
    I think "suicide" is a duff Japanese->English translation. While using an online automatic translator to browse Toyota Japan's site I got a few suicide references. Maybe it's a bad translation of "passenger"...?
  4. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Normally a suicide door would be a door that opens from the front to back, opposite your standard door. Like on a truck or Saturn coupe or the new Mazda RX8.
    Not sure why it's translating like that.
  5. Tempus
    1,690
    Washington DC
    It seems to me the author is confused here about exactly what the Hybrid Issues are:
    This makes it sound like there is electricity in the pillars around the roof. The issue there is Air-Bags which is far from a hybrid only problem.
    You have to check in ANY car now-adays before cutting the roof off.
  6. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    FYI: You might want to take a look at the Toyota '04 Prius Emergency Response Guide.
    It's written by Toyota specifically for emergency response workers, and has information specific to accessing the Prius safely in a crash situation.
    If you're interested in the Prius' electrical systems, this is a treasure trove of info.
  7. rflagg
    rflagg Member
    947
    Springfield, VA
    So, my question is, who's pushing out these articles - the oil companies, or the one of the big 3, or both? :)
    -m.
  8. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    'So, my question is, who's pushing out these articles - the oil companies, or the one of the big 3, or both?'
    Very good question!
  9. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Not in any way to degenerate the emergency workers' concerns, or the difficulty of their jobs: But when new technologies (air bags, dual batteries, etc.) have been used in automobiles, rescue workers have had to learn to deal with them.
    And they have. I suspect hybrids will be the next major thing on the horizon, assuming they catch on. (And with gas prices spiralling upwards, this seems likely). They'll deal with this like they have with past technology shifts.
    Now, if emergency services were to call for standardization in how hybrid electrical systems components are labelled (or colored), and how they work in emergency situations -- that sounds to me like a very reasonable demand. Particuarly once these groups have had a chance to deal with a few more hybrids in these situations, and know what the problems are, and what they'd like to see in the future.
  10. drivenmore
    drivenmore New Member
    28
    It's not "suicide seat". The phrase refers to the "seat behind the passenger's seat".
    Sometimes my liberal-arts bachelor's degree does actully come in useful.... :p
  11. paulisme
    paulisme New Member
    179
    Charleston, SC
    I'm imagining a similar article from The Onion that could have been written when motorcycles gained popularity:
    Rescue Workers Having Trouble Removing New Motorcyclists Bodies from Trees
    PITTSBURGH - The growing popularity of the motorcycle is a step toward high-speed travel and ultimately the modernization of roads in America. But for rescuers at accident scenes, they represent a potential new danger: getting a splinter while they try to unwrap a motorcyclist's body from a tree.
    "Usta be during the ol' horse and buggy days, the worst that would happen is a rider would get his head stuck up his mare's nice person and we'd have to siphon the manure out of his nose and ears," says old-timer Ray Moffer. "Pullin' a motorcycle out of a tree trunk and finding all the pieces of the rider is a lot tougher."
    Even with all the new found carnage, however, there remains a silver lining: "Them new-fangled helmets do come in handy, though," Moffer says. "You can use that chin-strap thingy as a handle to keep from gettin' blood on you when you finally find the cyclist's head in a ditch."
  12. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    :lolup: :lolup: :lolup:
    BTW, this story is really making the rounds -- it has a long discussion on SlashDot, and I've found it in several other places as well.
    The main thing several people point out that is incorrect in the original article: there are not high-voltage components in the Prius' doors or door columns (or in the sides of the car), and the hybrid battery is not 500+ Volts.
    One emergency response person said that side air bags are much more of a worry when cutting into a car than the hybrid system, since these are located in the areas they usually cut into.
  13. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I've already been approached about it by many people here at work who know I work on PriusChat and am into the hybrid "revolution". Talk about press spin. :roll:
  14. aarons12
    aarons12 New Member
    704
    long island, NY
    i agree. i'm a volunteer fireman and we have had to learn to deal with lots of new stuff over the years including AIDS exposure, home BBQ propane tanks, and others.
    and in the way of polite constructive criticism, your word for the day is 'denigrate'... as a volly, i am a proud degenerate, which is not to denigrate anybody elses efforts in that regard :mrgreen:
  15. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Oh joy, this story made it to slashdot.org - watch the speculation continue... :)
  16. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    Toyota's response, published today:
    Toyota Prius Engine Safety in the Event of an Accident
    05/04/2004 Torrance, CA
    The Toyota Prius gas-electric hybrid vehicle has many safeguards to help ensure safe operation for drivers and protection of emergency response professionals in the event of an accident.
    The high voltage batteries are contained in an extremely strong protective case located in a portion of the vehicle very unlikely to be penetrated in a collision. Drivetrain management computers continuously monitor all system functions performing hundreds of tests each minute. In the event an abnormal condition is detected, all high voltage circuits are disabled and high voltage is contained inside the protective case.
    Further, two safety mechanisms are in place that shut off the engine and disconnect high voltage if an airbag is deployed or if there is a sudden deceleration indicative of an accident. High voltage cables and components are heavily insulated, shielded, isolated and the cables are painted bright orange for easy identification. The controller box is a sealed unit and has warning labels.
    To reassure emergency response professionals when the Prius was introduced in 2000, Toyota placed advertisements in trade publications and sent letters to industry organizations announcing the availability and dissemination of Emergency Response Guides. Today, all Emergency Response Guides for Toyota's alternative fuel vehicles, including Prius, RAV 4 EV, CNG Camry and Highlander Fuel Cell Hybrid are available at Toyota's technical information web site and Toyota continues to advertise in appropriate professional publications.
    Electrically driven Toyota vehicles like the Prius, RAV 4 EV and e.com have been available in the U.S. since 1998. Like all vehicles, they can be involved in emergency situations. They have established a good track record for electrical safety and we are not aware of a battery case breach or any personal injury in the U.S. related to hybrid or EV electrical systems.
  17. HTMLSpinnr
    5,339
    917
    251
    Guess they aren't going to take FUD lying down :)
  18. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    :oops: Ha! Thank you for pointing that out. When it comes to spelling, I'm a sub-generate. :silly:
  19. skiguy
    skiguy New Member
    forget slashdot.com its on CNN.com....that how i saw it..
    i can see their concern but at the present time should not be too hard with only a couple models to know where to cut....
  20. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    One of my co-workers printed the story for me. I returned the favor by getting the Emergency Reponse Guide and printing page 13 for him. It documents normally open relays at the HV battery, which get deactivated in crash conditions.
