reservoir container filled with dark liquid
Discussion in 'Newbie Forum' started by Ian Simons, May 29, 2019.
Tags:
  1. Ian Simons
    Ian Simons Junior Member
    48
    Lake arrowhead
    There are two reservoir containers. One is the windshield wiper fluid and the other small one has some sort of dark liquid in it with a black rubber plug on top. The dark liquid is almost pass the max. Can someone please explain what the second container is, and if I should maintain it in any way?
  2. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    That container is your brake fluid. It needs to be changed.
  3. Mendel Leisk
    38,736
    Toyota USA says it's lifetime, I guess. Well actually, they say nothing.
    Toyota Canada, just in the last few years, says to change it tri-yearly or 30K miles (48K kms).
    Honda Canada, for as long as I can remember, says change it tri-yearly, regardless of mileage.
    The 3rd gen offical Repair Manual has an instruction, for brake fluid change without Techstream, and is relatively easy to DIY. 2nd gen I haven't found anything comparable, and I'd suspect it's best to check dealership service department for this. Try to verify they've experience at it...
    FWIW, here's a second gen brake bleed instruction from the Repair Manual, using techstream:
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Look in your service book for brake fluid inspection and service. If your car is older and this is the original fluid, fluid replacement might be in order. Brake fluid attracts moisture, thus the replacement interval.
    Edit - I don't see a service interval for brake fluid in the US manual. Just a check/inspect with no criteria for failure. If the brake fluid is very dark (as opposed to the somewhat dark of fresh fluid), it would not be unwise to change it.
    #4 jb in NE, May 29, 2019
  5. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    The spokesman for Bosch Brakes that spoke at the seminar I attended for my work actually recommended a 24 month change interval for brake fluid, and discarding any fluid that had been unsealed more then 6 months ago.
  6. Mendel Leisk
    38,736
    It'll be 3 years this fall since my last DIY change, will do it agin, while swapping over to snow tires. I'm sure you can do it without wheel removal, but it's not as accessible. Kudos to @NutzAboutBolts for blazing the way, btw.
    Again, haven't seen a second gen DIY.
    NutzAboutBolts likes this.
  7. orenji
    orenji Senior Member
    5,884
    3,486
    Brake fluid which appears to be pretty dirty. Better have it flushed.
  8. Ian Simons
    48
    Lake arrowhead
    Ty
