RESET BUTTON
Discussion in 'Gen 2 Prius Technical Discussion' started by deafelf, Jun 12, 2023.
  1. deafelf
    deafelf Junior Member
    Mississippi
    What does the reset under the steering column do?
  2. ChapmanF
    18,531
    It's a SET button. The icon next to the word is supposed to remind you of a tire.
    If you change your mind about what tire pressures you want, you can inflate the tires to whatever pressure you prefer, then use the SET button to tell the car "see the pressures in the tires right now? Those are the pressures i want" and it remembers those pressures.
    Other than that, it doesn't "reset" anything.
    If you have different tire pressures front and rear, you should use it after tire rotations (well, the tire shop probably already did for you), because the car remembers the pressures by transmitter ID, not by which corne of the car.
    If you run equal pressures, and you never change your mind about the pressures you want, you'll never have a reason to press it.
  3. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    it sets the parameter of the pressure desired, so the 20% loss trigger will work correctly..
    52,373
    careful, that's the ejector seat! :eek:
    Brucetafer likes this.
