Reset economy data
Discussion in 'Gen 3 Prius Main Forum' started by Sumedha, Jun 23, 2016.
  1. Sumedha
    Sumedha Junior Member
    52
    Colombo, Sri Lanka
    Does anyone know how to reset the ECU in a 2012 Prius by doing something else other than removing the 12v battery ?
    I did some changes which should improve fuel economy and if it uses older drive data, it could screw the predictions. I have heard that this needs a resetting time to time.
  2. mrbigh
    3,686
    699
    Long Island, NY
    No short cuts that we know
  3. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    You might be able to just remove the main 120amp fuse; but it is probably just as easy to remove the battery cable from the terminal.
  4. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    All you need to do is remove the Negative battery terminal for a few seconds and reconnect.
