Reseting Oil "light/warning" without tools - made easy
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rrolff, Oct 27, 2009.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Haven't seen this thread...
    To reset the "Service Oil" message, simply turn off the car, then turn it back on holding the KPH/MPH button...
  2. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    You didn't tell the whole story. You,
    1. Push the Trip button until the ODO displays totoal elapsed miles (not Trip A or B). Turn car off.
    1. Do not put your foot on the brake
    2. Hold the Trip button down and do not release
    3. Push the power button twice
    4. Continue to hold the Trip button until the ODO cycles through its dance and displays elapsed miles again.
    5. Release Trip button and turn power off.
    This is how I was told to do it and I've done it and it works.
  3. rrolff
    1,610
    246
    So Cal
    Thanks - it was the mechanic who did it, guess I just saw a piece :rolleyes:
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It's in the Owner's Manual...
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Yeah but it does work by simply holding down the odo button while powering up the car. At least in the gen2
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    From the Gen III owner's manual:
    The oil change system should be reset. Perform the following steps:
    Turn the “POWER†switch OFF with the trip meter A shown.
    Turn the “POWER†switch ON with the MPH or km/h button
    P. 183) held down.
    Keep pressing the button until the odometer indicates “000000†and
    the multi-information display indicates that the reset is complete.
  7. fjpod
    fjpod Member
    419
    72
    New York
    Wait! You forgot to mention that you are supposed to do this with your left arm tied behind your back...and you must use an unshoed left foot on the brake...while you hold your right eye covered. You must also wear a baseball cap backwards in the rally-cap position.
  8. paprius4030
    2,077
    296
    York,Pa.
    :eek: That is one of the funniest posts I've read here!
