Resetting Check Engine Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by moebius, Oct 22, 2005.
  1. moebius
    moebius New Member
    I've reset the check engine light in the past using a button combination on the dash in my 2005 but now I can't remember how. Can anybody help me out?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Check engine light or Service engine light?
  3. kaptaink
    kaptaink Junior Member
    52
    South Western NY
    Or did you mean the maintainence required?
  4. RoboChemE
    RoboChemE New Member
    SF Bay Area
    I just had my first oil change done. How do you turn off the "maintenance required" light?
  5. skhess58
    skhess58 Junior Member
    With the car off press and hold the ODO button. Step on the brake and hit the power button to go into READY (may work with IG ON too?). Keep holding the ODO button and watch the dash where the odometer readout usually is...you'll see dashes then the prior odometer reading will return and you can let go of the button.
    Now the maintainence light will flash on briefly upon start up in 4500 miles then will come on and stay on in 5000 miles
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Its also in your owner's manual under maintenance I think.
  7. Mystery Squid
    Mystery Squid Junior Member
    To "refine" these instructions a bit:
    Make sure you're set to ODO, not "Trip A" or "Trip B", or it won't work (drove me nuts for a few minutes until I figured it out). Turn it on, make sure you're on ODO, shut it down, then follow the directions above.
    As Danman said, it's in your manual, page 120 I believe (I just did it tonight after an oil change).
  8. Mystery Squid
    I think this should be PINNED.
    :ph34r:
  9. DanMan32
    3,799
    27
    Tampa Bay, FL
    Or part of it put in the KB. As I posted elsewhere, we seniors should get together and organize the KB forum.
  10. sundy58
    sundy58 Junior Member
    33
    Donna, TX
    I know this is old but: the owners manual is wrong. It says to be on trip "A" and that does not work as stated above.
  11. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Back to the OP, can you reset the CEL without going to the dealer or a mechanic?
    NOT asking about maintenance light reset.
  12. bisco
    52,375
    o/p only made one post 14 years ago, but i believe you can with a code scanner
  13. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    I didn’t realize the thread was that old, but sometimes these threads start off as one thing and get completely sidetracked.
    Thanks for the info. I think Patrick Wong in another thread mentioned disconnecting the negative terminal of the 12 V battery will also reset the check engine light?
    #13 SDB54, Oct 28, 2019
  14. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    Both methods will work, providing you have fixed the error that caused (is causing) it to light up. It is also a good idea to read the codes and record what they are before dismissing them.
    SDB54 and Mendel Leisk like this.
