Resetting the boulder detector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ChapmanF, Jul 22, 2018.
  1. ChapmanF
    17,343
    I changed my oil last night. Then, being the smug environmental do-gooder that I am, I took the old stuff to my handy local drop off.
    My oil tote was in the back, so as I backed up to the drop-off, confidently swinging the front of the car to (my) left, I was not watching the low boulder you see in the lower right, there.
    I might never have noticed at all, if The Prius didn't have such an effective built-in boulder detector.
    That's actually not the real before before picture. I wish I had taken the real before picture (it was dark though), because it looked really awful. The whole plastic rocker panel there below the door was all crumpled in, for an area matching the paint marks and somewhat beyond.
    I was thinking my best bet would probably be to remove the whole plastic rocker (six screws, 9 visible clips, 9 invisible clips, counting the rear wheelhouse front spat) and see if I could massage it back into shape with a heat gun. But by the time I went out this afternoon to get started, the sun had already done that whole job for me, and the rocker was completely back to its old shape, as seen above.
    That left the door to deal with. After a whole lot of whacks from the air hammer ...
    ... the shape I can probably live with. I'll still have to go looking for a paint-shop quote, because a man's GOT to know his limitations....
    The little Viair compressor in back is a bit slow to recover from each volley with the air hammer, but it turned out to be just about the right amount of time for closing the door and checking how the edges were lining up.
    Maybe I should just pay for my oil changes after all.
    -Chap
    jerrymildred and m.wynn like this.
  2. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Wow.
    I check my detectors almost every day hoping no rock was detected
    I have more trouble with the ice chunks detectors during winter
  3. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    good job with the air hammer/ (y)
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Good job banging out your door! Maybe bring your used oil to a local Walmart instead?! At least it eliminates the need for boulder detection! :ROFLMAO:
  5. Mendel Leisk
    40,582
    Lucky here: I can walk down a trail about 300 yards, to a Mr. Lube that has an accessible waste oil tank. Over the years I've had to drive to various places though; the current situation is a nice break.
    Yeah I would get a pro-shop to do it right, just my head space though, your call. Worth an insurance claim?
    amos and Bay Stater like this.
  6. ChapmanF
    17,343
    $773 at the dealer, which would represent (I'm hoping) the upper end of a range ....
    Small enough to be under my deductible I think, large enough to probably cancel all I've saved in my life by doing oil changes myself....
    -Chap
