Resetting Trip Odometer for A & B?
Discussion in 'Gen 3 Prius Fuel Economy' started by ben12345, Jun 1, 2011.
  1. ben12345
    ben12345 Junior Member
    32
    Orlando
    I tried to reset my Trip Odometer after my first fill up and everything seem to stay the same. The instructions seem to say hold the Trip button on the steering wheel for 3 seconds and it should reset. Does this reset A & B and does the display have to be on a certain screen when you push the reset button?
  2. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    If you want to reset trip A, select the trip A display first so that it's showing when you try to reset. Same thing for B. They have to be reset separately, and have to be showing at the time to reset them.
  3. Irwinprius
    Irwinprius New Member
    Los Angeles
    Sweet! Just what I needed. Thanks for the Q & A ! (Prius newbie)
    Burna J likes this.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    Welcome to Prius Chat !
  5. Mendel Leisk
    40,582
    While I do reset my trip meter (trip A) when I fill up, I also record the odometer reading. I rely on the odo readings for calcs, just use the trip meter for back up, and feedback.
    Mainly cus I want an unbroken record, and the trip meters can be accidentally reset.
  6. bwilson4web
    16,012
    I use "A" for the tank and "B" for experiments. The reason is I once reset "B" by accident but resetting "A" is more involved, less likely to make a mistake.
  7. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Yeah, they're too darn easy to accidentally reset. I soon learned to be quick on that Trip button, unless intending to reset "A" or "B". I use "A" for current trip, and "B" for distance since last complete fill-up (which isn't necessarily the same as distance since last fueling).
    Agree with Mendel about using only the odometer for official records, despite its larger rounding errors.
    #7 CR94, Sep 29, 2015
