Resistor Value for CAT when hot
Discussion in 'Gen 2 Prius Technical Discussion' started by MR.K, Apr 6, 2008.
  1. MR.K
    MR.K Junior Member
    86
    Idaho
    Anyone know the resistor value of the Cat sensor when it's hot? The motor cycles to keep it hot ..
  2. racerbob
    racerbob Member
    138
    S Florida
    I don't think it works that way. I think cat temp is calculated from run time and the post cat O2 sensor. They work most efficiently at 600 deg F and higher. Post cat sensor on a Prius doesn't stay at any fixed value that can be easilly generated to fool the ECU.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Correct -- there's no actual sensor for cat temp, it's inferred.
    There are AF/O2 sensor heaters, that's about it...
    _H*
  4. MR.K
    MR.K Junior Member
    86
    Idaho
    Thanks ...just thought you could fool it so the ICE would not run to keep it warm ....
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Surely you don't want to spew more emissions into the air, do you?
