Retrofiting to run on battery only for short runs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeri, Jul 30, 2008.
  1. Jeri
    Jeri New Member
    Another Prius owner (06) told me he was going to have his car retrofitted so that he could make the short daily runs on battery only. This he says will improve his mpg. Is this really possible? I also have four short runs per week and I know that this takes a toll in my mileage. Mine is an 05 if that makes a difference.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Two retrofits come to mind, one expensive but effective, the other inexpensive but not effective for saving fuel through battery-only propulsion.
    The first is an additional battery, likely with plug-in charging capability. Very pricey, likely not cost-effective (yet ... hopefully prices will drop), and technically difficult. It's not a job for a shadetree mechanic.
    The second is an "EV switch" (as in Electric Vehicle switch). I have that, but I do not use it for sustained battery-only propulsion. Instead, I use it mainly to shut the engine off during its warmup cycle when it won't shut off spontaneously. See this for more.
  3. richard schumacher
    7,664
    1,045
    United States
    Because of the inefficiencies of energy conversion and battery charge/discharge, using the battery more usually reduces fuel economy, unless you manage use of the battery very closely (or unless you have a plug-in conversion; that costs $10,000 and will void your warranty).
    Uhh, doesn't that indicate that the engine and/or the catalytic converter have not warmed up enough? You may improve fuel economy but increase pollution.
  4. JimboK
    2,817
    188
    49
    Chesterfield, VA
    The EV switch doesn't work during S1 when, as I understand it, the cat warmup occurs.
    No one seems to have any explanation for some of the other warmup idiosyncracies, such as why it will shut down in S2 at a standstill but not while moving, or why in S3 it will shut down at speeds above 34 MPH but not below. Reducing emissions wouldn't seem to explain the logic of these design features. It seems to this simple mind that, once the cat is warmed, running the ICE pollutes more than not running it. I stand to be corrected and educated, of course, if someone has evidence to the contrary. Always looking to learn more about this remarkable car.
