Return of Physical Button controls
Discussion in 'Fred's House of Pancakes' started by Prodigyplace, Mar 11, 2025.
  1. Prodigyplace
    12,709
    11,847
    Central Virginia
    Isaac Zachary and Mendel Leisk like this.
  2. ETC(SS)
    7,472
  3. Mendel Leisk
    42,219
    "Physical Buttons" needs more qualification?
    Our '10 has physical buttons, one being the vent mode. Which you'd like to access, on a twisty road, nighttime, raining, because the windshelds starting to fog up. It's here:
    Ensconced in a row of similar buttons, uniform and flush, with a wee text ID. Ok, you've found it, after looking down 3~4 seconds, got a finger on it.
    Now, just one hand on the steering wheel, you glance up to ensure you're not going off-road yet, push the button once, glance down, squinting to see the LCD display for a reaction:
    Ok, it shows this:
    Glance up at the road again, one-handing along still, another push of the button, glance down:
    Dang, glance up at the road again, another push:
    Eureka! And that's as good as it gets; no directing all the air to the windshield, at least not with the regular modes.
    Then there's the base model Honda Fit, long since discontinued for North America, and this dash style likely long since discontinued, everywhere:
    ^ There's only two actual "buttons", they're distinct, on the lower left and right corners, and for largely set-and-forget functions. The other functions, recirc/fresh, temperature, fan speed and mode are all tactile, easy to find and adjust by feel alone. IIRC, Honda's mode dials had intermediate detents that you could feel as you rotate, so you've got the two extremes, and 3 detents for the intermediates.
    I hope VW does it right; I'd be interested.
    #3 Mendel Leisk, Mar 11, 2025
    Winston Smith likes this.
    52,740
    I think Hyundai did also. The problem is cost in terms of competitive models, and what do the next generation of buyers want.
  5. Prodigyplace
    12,709
    11,847
    Central Virginia
    There appears to be some European safety rating encouraging this. I know the 2025 Camry is not too intuitive. There is one owner on TN that keeps hitting the "trunk open" when they want either the panoramic cameras or the fuel door release. LOL The HVAC controls put some of the buttons where other buttons just have a display.
    Auto high beam switch
    Traction control on/off
    Instrument panel light control
    Panoramic camera switch
    Trunk opener
    Fuel filler door opener
    For HVAC, I needed to do a screen grab to show the actual controls.
    Top row:
    Auto LED
    Drivers seat heater switch & LEDs
    Drivers seat ventilation & LEDs
    Drivers temperature display
    Fan speed display (Auto mode does not show fan speed)
    Heated steering wheel display (includes an Auto mode)
    Air direction indicator (Auto mode does not show direction)
    Passenger temperature indicator
    Bottom row
    Auto on/off switch (toggle)
    Heated side mirrors switch & LED
    Heater rear defroster switch & LED
    Driver temperature set switch (up/down)
    Fan speed switch (up/down)
    Heated steering wheel switch
    Air flow switch
    Passenger temperature set switch (up/down)
    Temperature sync switch & LED (driver temperature controls both)
    Recirculate switch & LED (Auto mode does not show status)
    AC switch & LED (Auto mode does not show status)
    It is quite the complex mess.
    #5 Prodigyplace, Mar 11, 2025
  6. bisco
    52,740
    When buttons, knobs and switches were standard, there were a lot less things to operate
  7. Mendel Leisk
    42,219
    Concur. :(
    Prodigyplace likes this.
  8. Prodigyplace
    12,709
    11,847
    Central Virginia
    See my post above yours for the 2025 Camry LOL
  9. bisco
    52,740
    It’s amazing we still can’t make voice commands work
  10. Prodigyplace
    12,709
    11,847
    Central Virginia
    It does have voice commands. They were demoed but I do not use them.
    The salesman tried to have the built in navigation go back to the dealer but it could not find it by name. giving the address displayed the name LOL
    Other than navigation, voice assist works with seat memory & "ambient lighting".
  11. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Toyota used to have a system where there were three ball-shaped switches in a row to control air and heat. Once you learned it you could just tap your way along the dash, know exactly how you had set it, and never once look away from the road.
    The capacitance switches suck.
  12. ETC(SS)
    7,472
    BUT....they're cheap.
  13. Paul Gregory
    Paul Gregory Senior Member
    2,328
    610
    Alberta
    2024 Prius Prime
    XSE
    In my ideal world, the physical buttons would have an OLED screen embedded in them that changes with context.
    Currently, too expensive except for airliners and slot machines.
  14. ETC(SS)
    7,472
    In MY 'ideal world' the only OLED screen inside a car would be on a phone that is charging in the center console.
  15. Prodigyplace
    12,709
    11,847
    Central Virginia
    Something longer lasting than OLED needs to be used. Avoid planned obsolescence.
  16. Paul Gregory
    2,328
    610
    Alberta
    2024 Prius Prime
    XSE
    The Gen 5 has a wireless charger in the center console, but the reception is not good in there, so I don't use it.
  17. ChapmanF
    18,919
    So I still have to look at them? Yuck.
  18. Paul Gregory
    2,328
    610
    Alberta
    2024 Prius Prime
    XSE
    Don't look at anything then. Less driver fatigue.
  19. Prodigyplace
    12,709
    11,847
    Central Virginia
    Not for other divers on the road around them... :D
  20. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    99
    34
    117
    lancaster, california
    ... intended for hinterland farmers, a means of keeping their livestock productive, in the field, mass produced automobiles were supposed to be engineered nibble, practical, serviceable, user-friendly, lightweight, far more efficient, practical a means of rural to urban locomotion, than their horse-drawn, oxen drawn ladder-framed carriage antecedents.
    How could it be? How is it possible a contemporary 2-door, two-wheel drive Corvette or Mustang, weights more than my 4 door, 4WD station wagon?
    Epitome of absurdity? No engineer worth his salt, given a clean sheet of paper, would mandate an SUV profile wheel diameter, to the Subaru/Toyota BRZ/GR86 platform.
    Current offerings are fat, overweight, overloaded, over-optioned, woefully overpriced, poorly designed. Over reliance on electronics for functions better suited to an honestly mechanical refinement, we're asking too much of contemporary vehicles, heaped upon a preponderance of over-electrified nonsense.
    Not one current offering you could point to, where form follows function. Iaccoca's original Mustang, weighed 2,445 pounds, more than a thousand pounds less than its 21st century postceedent. A BRZ would be 5 seconds a lap faster, with an optimized 15" wheel diameter. Engineer a Tesla properly, reduce ride height and reciprocating mass with a 14" wheel diameter, that alone, you'd increase its range circle, a hundred miles.
    Goo-goo gah-gah? Baby wants a really-big touch screen, in their toaster oven car?
