Return to ACC mode from READY?
Discussion in 'Gen 3 Prius Technical Discussion' started by Azimuth, May 3, 2010.
  1. Azimuth
    Azimuth Member
    136
    32
    Austin
    Does anyone know if there is a way to get out of ready mode and back to accessory mode without a full power cycle.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    The only way I have found is to turn it off then back to accessory mode.
  3. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Same here, the only way to do it is to turn the car off, and back into accessory again as far as I know.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You twist the power button to the left. :)
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I wish more cars had behavior like some of the GM cars had (even el-cheapo ones that were otherwise crappy): they keep the stereo on when you turn off the ignition until you open the driver's door. I don't know if there's a timeout but there didn't appear to be one.
    No Toyotas and Nissans that I've encountered do the above.
  6. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    So you are telling us that the accessories are switched on by turning off the ignition, with no separate acc. switch position? Or is it just the radio/stereo that is activated?
  7. bwilson4web
    16,011
    Near as I can tell:
    • car off, no brake, press POWER - turns on radio and 12 V plugs. Does not allow window operation. This seems to be accessory mode.
    • accessory mode, no brake, second press POWER - turns on displays and control computers. This is the same as IGN without START.
    • IGN mode, no brake, third press POWER - turns car off
    • any not-READY mode, brake, any press POWER - READY
    Probably need to have some independent confirmation. Perhaps a state diagram someone?
  8. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Seems to me that accessory mode is necessary to allow window operation, at least in my limited experience.
  9. tumbleweed
    4,067
    690
    Eastern Oregon
    The windows will work in the Ready mode or Power mode but not in the Accessory mode. They will keep working for a minute or so after you go to off.
  10. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Yeah. That's one of the dumbest "features" of modern cars. Makes me long to a return to windows that you actual crank up or down yourself.
  11. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Just hit the power button twice in quick succession.
    What's so difficult about that?
  12. Azimuth
    Azimuth Member
    136
    32
    Austin
    It causes my navigation to reboot. I know.. 30 seconds isn't long. but it's just something I was curious about.
  13. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I agree, It would be a nice feature to have. From Ready(running/start) to Acc without having to lose power to the radio system. Its a pain when you are playing an MP3 cd and the stereo power cycles and has to "load" the tracks again.
    a delayed accessory mode would be quite convenient.
  14. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Would putting it in PARK accomplish what you want to do?
  15. bwilson4web
    16,011
    There was a hack with the earlier Prius to keep the 12 V. system live on the auxiliary power plugs (aka., cigarette lighter.) What you're asking for would be some sort of 'time delayed', say 30-60 seconds, on the accessories. There are time delayed relays available that can keep a voltage up for different time intervals.
    I need something like this for my auxiliary plug in the NHW11. I'll get two and add it to my 'to do list.'
  16. Azimuth
    Azimuth Member
    136
    32
    Austin
    This would be a cool mod!
