Reverse beep and Service reminder
Discussion in 'Gen 2 Prius Main Forum' started by tfelder, Apr 9, 2006.
  1. tfelder
    tfelder New Member
    I'm not sure which forum to use so I'll try this one.
    When you disable the reverse beep you press and hold the Odo button and then press the Power button.
    When you reset the Service Reminder you press and hold the Odo button and then press the Power button.
    Is the Service Reminder reset when you disable the reverse beep?
    Thanks,
    Skip
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(tfelder @ Apr 9 2006, 09:43 AM) [snapback]237178[/snapback]</div>
    The service reminder is reset by holding both the ODO and TRIP buttons down and pressing start.
  3. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(seasalsa @ Apr 9 2006, 01:39 PM) [snapback]237184[/snapback]</div>
    On my 2006, the Odo button is also the Trip button (it is labeled ODO above the word TRIP). When I turned off the reverse beep on Barb's 2005 at about 1000 miles, it did not seem to affect the service reminder which came on right when it should have (solid on at 5000 miles). I did my 2006 when I first picked it up new, so I won't be able to tell.
    - Tom
  4. tfelder
    tfelder New Member
    Thanks for the responses.
    The next time I disable the reverse beep (on a friends Prius) I'll watch the odometer readout to see if it indicates a reset of the service reminder.
    I forgot to post that mine is an '06.
    Skip
  5. j_johnso
    j_johnso New Member
    I disabled the reverse beep on my '06 and the maintenance light still came on at 5000 miles, so I guess it does not reset the maintenance light if it is off. I don't know if it will reset it if it is already on.
  6. daniel
    14,487
    1,518
    Spokane, WA
    Since Disable Reverse Beep is a regular function, documented in the owner's manual, it should not affect the service reminder.
  7. aaf709
    3,862
    2022 Prius Prime
    Both use the Power and the ODO buttons, but the timing is different. I accidentally reset the Maintenance reminder by forgetting that.
